Uncertainty in Measurement (Question)
If a measured average value exceeds the true value by 10% while the uncertainty in measurement is less than 10%, it suggests potential issues with the data or experimental method. Uncertainty should ideally create a "bubble" around the average value that includes the true value, assuming all errors are accounted for. If the measured value falls outside this bubble, it raises questions about the accuracy of the measurement or the validity of the true value. A personal example highlights that discrepancies in measurements can occur, and sometimes the newer method may yield more accurate results. Accurate data analysis requires careful consideration of both measurement uncertainty and the true value.
BAnders1
In regards to data analysis, what would it mean if you measured some quantity, say the speed of light for example, and you measured an average value that was 110% of the true value. If your uncertainty in measurement is LESS than 10%, does that mean that something is wrong with your data or experimental method?
In general, should the uncertainty in measurement create a "bubble" around the average measured value that always encloses the true value, given that your experimental method and theory is correct, and that you accounted for every possible error?
If you believe your data, and your estimate of statistical uncertainty, then the "true value" might be wrong. In my PhD thesis, I used a new and very precise method to measure a parameter that was previously measured by my thesis advisor 10 years earlier. My measurement was two (of his) standard deviations lower, and his was 30 (of my standard deviations) higher. My measurement turned out to be correct. (I got my PhD anyway.)
Bob S
I think it's easist first to watch a short vidio clip I find these videos very relaxing to watch .. I got to thinking is this being done in the most efficient way? The sand has to be suspended in the water to move it to the outlet ... The faster the water , the more turbulance and the sand stays suspended, so it seems to me the rule of thumb is the hose be aimed towards the outlet at all times .. Many times the workers hit the sand directly which will greatly reduce the water...
