Uncertainty principle on P and E exchange
luxiaolei
Hi,all, I am wondering, momentum can expressed as energy, so:
dxdP can expresses as dxdE ?
then position, momentum, energy,time are all related, and they all form uncertainty relations??
in the view of commute the operators, all these four operators can NOT commute??
where am I wrong?
Thanks in advance!
The total energy depends on position as well, thus does not commute. You could say for a free particle everything commutes however in a universe with only a single particle I am not sure such a term as position would even exist as it is a relative term.
Thanks for replay,LostConjugate. I am very interested in what you said free particle's all operators commute, would you please explain it more? Thanks
Actually it still does not commute with position. A free particle's energy only depends on the momentum and not the position because it is in a universe where there are no other forces. So the total energy would commute with the momentum.
This is true.
where am I wrong?
Thanks in advance!
It is true that in classical mechanics, kinetic energy can be expressed in terms of the momentum as p2/2m. However, in QM, momentum is an operator, so you need to be a little more careful. You can construct the analogous kinetic energy operator as:
\hat{K}=\frac{\hat{p}^{2}}{2m}=-\frac{\hbar^{2}}{2m}\nabla^{2}
Also, you seem to be neglecting potential energy in your question, V(x), which is in turn a function of position. The total energy is of course always the sum of the kinetic and potential energies.
To answer your question, the following pairs of operators commute:
1) momentum and kinetic energy
2) position and potential energy
The following pairs of operators never commute:
1) momentum and position
2) kinetic energy and position
The following pairs of operators do not commute in general, but can in special cases (like the free particle, where V=0):
1) momentum and potential energy
2) kinetic energy and potential energy
HTH
LostConjugate:
right, start to make sense now, thanks alot. so it comes an conclusion:
if precisely measure time then enlarger E and P, then result in precise the position, am I right? position and time, if measure one of them precisely, the other one will locate precisely automatically?
Better answer Cat :) The way I always remember it is that you can't have an exact position if you have a momentum. Simply because momentum is dx/dt and an exact position would require dx = 0. Therefore... uncertainty existed far before QM.
Since E = p = x/t everything is uncertain.
luxiaolei said:
LostConjugate:
If you measures position to an exact measurement you will no longer be able to measures momentum, because dx = 0 and p = dx/dt (or in QM d^2/dx^2) so now how to you calculate that?
Same goes for measuring momentum, you will no longer get an exact position, it is either one or the other.
@luxiaoloei: This is the whole reason that QM is probablilstic and not deterministic... we can't ignore that. If not, why \Psi ? right?
Thanks all! :)
