Undergrad: General Astronomy Questions.
The discussion focuses on various astrophysical concepts related to general astronomy coursework. Key topics include the causes of periodic photometric variations in stars, with suggestions of rotation, pulsations, and nearby objects affecting luminosity. The chain of events leading to pulsations in stars within the instability strip is described as a cycle of radiation pressure and gravitational forces. The beta-index is mentioned as a luminosity indicator related to H-beta lines, with requests for clarification on its definition and application in photometry. Lastly, the presence of stellar winds can be inferred from a star's spectrum, particularly through the observation of P-Cygni profiles, especially in hot, luminous stars.
fasterthanjoao
I've been reading over my astronomy coursework and trying some questions, and I'm coming across a few things I'm not sure about, i'd be grateful if you could provide the answers.
1/ Give three possible astrophysical reasons for periodic variations in the observed photometric signal from a star.
What is thought to be the source of the photometric variation in the H-alpha emission line signal from a Be star?
- for this question, I can only think of: rotation of the star? or pulsations (like a cepeid or something) or something passing in front of the star. I'd be happy if you could correct or expand.
For the second part, I'm sure the 'e' in Be has something to do with the H emission, and I think B stars are associated with having a disk of material - is this along the correct track?
2/
Describe the chain of events that causes stars in the instability strip to pulsate.
- Here, I'm assuming that they're looking for information such as; radiation pressure forces the layers to expand, pushing further and further out until the density is low enough that the radiation escapes more readily and the push isn't as effective, allowing gravity to take over - pulling it back in? A pushing/restoring force sort of thing.
3/ I keep seeing reference to the beta-index, as far as I can work out it's some sort of luminosity indicator, but I'm not sure what it actually is and I can't find much in my textbooks - is there an expression describing it? and how would I describe the process of beta-index photometry?
4/ Describe how a stellar wind could be inferred from a stars spectrum.
- Is this something to do with a P-Cygni profile? would I see a P-Cygni profile when I look at a spectrum from a star with a wind? And am I correct in saying that winds are more common in stars that are hot/luminous because high particle velocities, high energies and it's easier for the particles to jet off?
I realize this post is long, and I'm not asking you to read it all, but if you could give me feedback on any question, it's well appreciated.
thanks.
Astronomy news on Phys.org
I think in question 1, that in addition to the physics of the star, a nearby object, e.g. another star in a binary system, or planet, will obviously decrease the apparent luminosity, and then there could be a nebula or dust cloud nearby.
Reference to beta index here "The nature of Balmer line variability in chemically peculiar stars" -
http://adsabs.harvard.edu/cgi-bin/nph-bib_query?bibcode=1986AcA...36..131M&db_key=AST&amp
and here - http://www.univie.ac.at/tops/CoAst/archive/DSSN2/QConstant.html
and here - A sub-millimetre survey of the Galactic Plane
http://www.astro.keele.ac.uk/~ae/
and this looks interesting - http://www.edpsciences.org/articles/aa/pdf/2005/42/aa2491-04.pdf
Seems like beta index has to do with the H_\beta lines.
I'll pass on #2 and #4 - you need SpaceTiger, Cronos or Garth for those.
More useful stuff (maybe) -
http://ie.lbl.gov/education/glossary/glossarya.htm#
http://scienceworld.wolfram.com/astronomy/
thanks for the response, those links were helpful.
Astronuc did a nice job, as usual.
1] Obviously, eclipsing binaries and intrinsic variables cover 2/3 of Q1. The third possibility is most likely polarization effects resulting from axial tilt.
2] Pretty much, if I understand the question correctly. See:
http://ams.astro.univie.ac.at/?s=pms
3] See also:
The H Beta Index as an Age Indicator of Old Stellar Systems: The Effects of Horizontal-Branch Stars
http://www.arxiv.org/abs/astro-ph/0004247
4] Yes. See:
X-Ray Plasma Diagnostics of Stellar Winds in Young Massive Stars
http://www.arxiv.org/abs/astro-ph/0110035
Pretty tough questions for an undergraduate course!
TL;DR Summary: In 3 years, the Square Kilometre Array (SKA) telescope (or rather, a system of telescopes) should be put into operation. In case of failure to detect alien signals, it will further expand the radius of the so-called silence (or rather, radio silence) of the Universe. Is there any sense in this or is blissful ignorance better? In 3 years, the Square Kilometre Array (SKA) telescope (or rather, a system of telescopes) should be put into operation. In case of failure to detect...
Thread 'Could gamma-ray bursts have an intragalactic origin?'
This is indirectly evidenced by a map of the distribution of gamma-ray bursts in the night sky, made in the form of an elongated globe. And also the weakening of gamma radiation by the disk and the center of the Milky Way, which leads to anisotropy in the possibilities of observing gamma-ray bursts. My line of reasoning is as follows: 1. Gamma radiation should be absorbed to some extent by dust and other components of the interstellar medium. As a result, with an extragalactic origin, fewer...
Both have short pulses of emission and a wide spectral bandwidth, covering a wide variety of frequencies: "Fast Radio Bursts (FRBs) are detected over a wide range of radio frequencies, including frequencies around 1400 MHz, but have also been detected at lower frequencies, particularly in the 400–800 MHz range. Russian astronomers recently detected a powerful burst at 111 MHz, expanding our understanding of the FRB range. Frequency Ranges: 1400 MHz: Many of the known FRBs have been detected...
