Understanding 3-pin vs 380/415V Electrical Supply
  • Thread starter Thread starter vultac
    Electrical Supply
The discussion focuses on the compatibility of 3-pin (UK) electrical supply with equipment requiring a 380/415V 3-phase supply. Converting single-phase to 3-phase is technically possible but costly, involving complex processes like converting to DC and using pulse width modulation. In Australia and likely the UK, domestic supplies can access 3-phase power at street level, with the option to have all three phases brought into homes for an additional fee. The voltage between phases is approximately 415 volts, which may be suitable for the equipment in question. Understanding these electrical supply differences is crucial for proper equipment setup.
vultac
Hi Guys,
Im staying in a country that has 3-pin (UK) electrical supply.
I recently come across one of my equipment that need 380/415V 3ph 50hz 4 wire supply.
Please advise isit possible to hook them up? what's the difference.
It is possible to convert single phase to 3 phase, but it is expensive to do this.
It involves converting the single phase to DC then chopping the DC into three streams of pulse width modulation, each 120 degrees apart.
So, you wouldn't do it unless you really had to.
However, the domestic supply in Australia (and probably the UK) is 3 phase at street level and one of the phases is brought into houses with a neutral. By paying extra, you can get all three phases brought into the house.
The voltage between phases is 240 * √3 or 415 volts.
This might be suitable for your machine.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
