Understanding a Push-pull amplifier schematic.
The discussion revolves around understanding the operation of a push-pull amplifier schematic, focusing on the configuration and function of various components within the circuit. Participants explore the roles of transistors, biasing, and thermal stability in the context of amplifier design.
  • One participant questions the placement of the input at the collector of Q1 and seeks clarification on its operation compared to more common structures.
  • Another participant clarifies that the collector of Q1 is not the input but rather the output of the previous stage, suggesting the schematic may be incomplete.
  • A participant speculates that Q1 varies its collector current based on an earlier stage's input and discusses the implications of Q1 not conducting.
  • One contributor asserts that the output stage has an AC voltage gain of one and that the emitters of the output transistors closely follow the collector voltage of Q1.
  • A participant describes the circuit as a standard class A driver for a complementary pair of emitter followers, explaining the push-pull operation in terms of Q2 and Q3's conduction cycles.
  • Another participant notes that Q1 serves as a prior stage for lower-level signal amplification, indicating that its output configuration could vary.
  • One participant raises a question about the necessity of quiescent current in relation to thermal stability, referencing resistors R3 and R4.
  • A later reply elaborates on the function of R3 and R4 as emitter resistors providing local feedback, emphasizing their role in the emitter follower configuration and the importance of biasing to avoid crossover distortion.
  • Another participant expresses confusion regarding the purpose of additional bias voltage from R2, indicating a need for clarification.
Participants express varying levels of understanding regarding the schematic and its components, with some clarifying roles and functions while others remain uncertain about specific aspects, particularly concerning biasing and thermal stability. No consensus is reached on the necessity of quiescent current.
There are unresolved questions about the completeness of the schematic and the implications of certain design choices, such as the use of biasing components and their effects on thermal stability.
The wiki link didn't work for me. The collector of Q1 is not the input. It is the input to the last stage, but the output of the previous stage. The image looks incomplete towards the bottom of Q1.
I suppose that Q1 causes a variation of its collector current according to the input somewhere in the previous stage. I see that if Q1 isn't conducting at all the last stage 'pushes' current to the load (not shown here). But what about 'pulling' it?
Try this link: http://en.wikipedia.org/wiki/Push-pull_output
Without showing any more of the schematic in your first link you cannot really say if Q1 ever goes completely out of conduction. Based on my experience I would say that it should not. There just isn't enough there to tell any more than this. What you can be sure of is that the output stage has an AC voltage gain of one and the emitters of the output transistors will follow pretty closely what is on the collector of Q1.
Your image is a bog standard class A driver for a complementary pair of emitter followers operating in class AB.
The input of the stage is to the base of Q1. It's output is developed, largely across R1 and feeds both bases of the output pair. R2 and the two diodes form the small bias to (nearly) remove crossover distortion.
Since Q2 and Q3 are of opposite polarity each conducts on half a cycle and is cut off on the other half, making the 'push-pull' arrangement.
It is called push-pull because the output is alternately pushed up towards the +ve supply as Q2 conducts and Q3 is cut off and then pulled down towards the negative supply as Q3 conducts and Q2 is cut off.
go well
Q1 is simply the prior stage. Push-pulls are usually output stages so there is generally prior stages more optimal for lower level signal amplification. Q1 is that. It happens its output comes out of the collector (and input the base, hence CE configuration) but it could have been different, e.g. CB cascode output.
Ok, thanks! I understand it now but there is another detail: The book says that R4 and R3 improve thermal stability since there is a voltage drop of few tenths across them that can be controlled with R2. But wouldn't it be better that there wasn't any quiescent current at all?
No sure what you have understood here.
R3 and R4 are emitter resistors that provide a small amount of local emitter feedback to each output transistor. This has nothing to do with with the push-pull arangement and is basic to the emitter follower (common collector) configuration that Q2 and Q3 are in.
If you do not understand this I suggest you go back and revise that part of your notes it is really basic.
In order to be just at the edge of conduction each of Q2 and Q3 need to be biased the equivalent of one forward pn junction - the base emitter junction. Hence the two diodes.
Using a diode instead of a resistor thermally stabilises the transistor since the diode junction reacts the same as the transistor junction to temperature change, unlike a resistor.
The purpose of R2 is twofold.
Firstly the voltage across it provides the extra bias to compensate for R3 and R4.
Secondly adding a small base bias on top of this puts Q3 and Q4 just slightly beyond the edge of conduction into actual conduction. This is done to eliminate the unwanted highly non-linear transfer characteristic at the origin called crossover distortion.
You may be confused with the use of the term bias.
R2 and the diodes provide voltage bias to the bases of the two output transistors.
This results in a small collector bias current in both transistors. It is this bias current that is meant when referring to setting the amplifier bias.
go well
Ok, I was confused with the purpose of adding some extra bias voltage with R2. Tanks for your help.
  • · Replies 33 ·
  • · Replies 22 ·
