A Understanding Barandes' microscopic theory of causality
  • #151
Sambuco said:
I will attempt to describe a position that seems reasonable to me. First, transition matrices define a nomological entity that is only relevant to the extent that we have (contingent) information about the outcome of an event. That is, given a division event at ##t'##, the standalone probability ##p_i(t)## can be written as ##p_i(t) = \sum_j \Gamma_{ij}(t \leftarrow t') p_j(t')##, where ##p_j(t')## are, in Barandes's words, "the contingent ingredient". Then, if we have precise information about the system configuration at ##t'##, all of the probabilities ##p_j(t')## become zero, with the exception of one, which corresponds to the observed value. Applying this information to our expression for the standalone probability ##p_i(t)##, we obtain ##p_i(t) = \Gamma_{ij}(t \leftarrow t')## where ##j## refers here to the system configuration ##q_j(t')## for which we have information. That's the "collapse" in this stochastic formulation.
Now, how is it possible for all the other branches still exist if the aforementioned standalone probability only includes one of them? In other words, how is that possible for different branches to recohere (as in Wigner's friend thought experiments) if they are not included in this standalone probability? Well, the answer lies in the fact that what is "objective" is the transition matrices, not the standalone probabilities, since the latter also depend on contingent information about the ocurrence of other events. In cases such as Wigner's friend scenarios, the recoherence of different branches is intrinsically related with the loss of information about the system configuration at ##t'##. Without this information, we have to use again the ##\Gamma(t \leftarrow 0)## transition matrix because, in addition, the dynamics are no longer divisible at ##t'##.
@Morbert, I think you'll agree. Am I right?
Lucas.
The divisible transition map of quasiclassical subsystems are near exact. This means they will effectively never fail. You would need to introduce superobservers capable of suspending irreversibility or specific models of the universe permitting Poincare recurrence (for such a universe the size of our observable universe the recurrence time would be something like 10^(10^122)).
Note that Albert is not considering these speculative scenarios. He is considering timescales of at most a couple centuries. The divisible stochastic map obtained from marginalizing over environmental degrees of freedom is effectively exact for these timescales.
  • #152
I agree, but... The issue I tried to address in my last post is about how it is possible, within Barandes's formulation, to restrict the system configuration for ##t > t'## to only one of the possible branches, while still preserving the other branches for those cases with superobservers, Poincaré recurrence and so on. The only way I see to achieve this within Barandes' formulation is by letting the information about the occurrence of an event at ##t'## play an active role through the (contingent) probabilities ##p_j(t')##. As long as we are certain of the outcome of the event at ##t'##, the probability of a future event will be determined exactly by the transition matrix ##\Gamma_{ij}(t \leftarrow t')## associated with the branch corresponding to the outcome at ##t'##. Interference between different branches is still possible whenever something happens that is equivalent to erasing all information about the outcome of the event at ##t'##.
I disagree. Marginalizing over environmental degrees of freedom only causes the probability of a future event to be represented by a statistical mixture, not the system to remain on a single branch.
Lucas.
  • #153
The divisible subsystem transition map prevents the configuration of the subsystem from jumping across quasiclassical branches. The divisible transition map is a near exact description of the subsystem, and only fail to apply in the superobserver/recurrence scenarios I mentioned above. You seem to be suggesting the divisible transition map applies even in these speculative scenarios. It does not.
The transition map obtained by marginalizing over environmental degrees of freedom will indeed prevent the system from jumping across branches.
  • #154
No. What I said (or at least tried to say) is that if there is information (even in the environmental degrees of freedom) about the outcome of the event at ##t'##, this makes it a division event, and the standalone probability of a future event is exactly ##p_i(t) = \Gamma_{ij}(t \leftarrow t')##. If, on the other hand, that information is erased, there is no longer a division event at ##t'##, so the stochastic map is now ##p_i(t) = \Gamma_{ik}(t \leftarrow 0) p_k(0)##. I think we both agree on that.
Maybe I'm misunderstanding you. Marginalizing over environmental degrees of freedom produces the transition map ##p_i(t) = \sum_j \Gamma_{ij}(t \leftarrow t') p_j(t')##. Are you also saying something like "What this statistical mixture means is that the system is constrained to a single branch, we just don't know which one it is"? If that is the case, I agree.
Lucas.
  • #155
I'm not sure what you mean by "the stochastic map is now [...]". The stochastic map of the universe ##\tilde{\Gamma}(t\leftarrow 0)## is indivisible. The stochastic map of the quasiclassical subsystem ##\Gamma(t\leftarrow 0)## is divisible, as the subsystem is regularly imprinting on environmental degrees of freedom in the universe. If, in the future, some speculative process like a superobserver or Poincare recurrence renders ##\Gamma(t\leftarrow 0)## unreliable, it will have still have been reliable for the timescales of human history Albert brings up. I.e. We can use this divisible stochastic map to reliably infer Napoleon from his records, even if in the very very very distant future it might no longer be a reliable stochastic map.
I probably agree with the spirit of your quoted statement, but a transition map is not a statistical mixture. What you have posted above is a linear marginalization relation. The marginalization that yields a divisible transition map is equation (50) in Barandes's paper. In that section, he derives the subsystem transition map ##\Gamma^\mathcal{S}## from the subsystem + environment transition map ##\Gamma^\mathcal{SE}##.
A transition map says nothing about what state the system is in. It is instead the dynamical rule by which the system will evolve, whatever configuration it is in.
[edit] - I'm not saying you disagree. I'm just trying to tighten up the language.
  • #156
@Sambuco Maybe the conversation can be refocused by telling me which statement you disagree with.
i) The transition map of the entire universe (under appropriate assumptions about the universe) is indivisible.
ii) Following Barandes's procedure 3.7, we can write down a candidate transition map of the Earth that is divisible.
iii) Until we are at recurrence times, or until a superobserver imposes their will on the universe, the transition map from ii) will reliably describe the dynamics of Earth. So much so that it is effectively exact across human timescales.
iv) This transition map will constrain the configuration of Earth from "jumping across quasiclassical branches". I.e. It will ensure the Earth evolves quasiclassically.
v) Therefore, humans can use the transition map from ii) to reason about the past state of the Earth based on present-day observations (e.g. infer Napoleon existed based on records of his campaigns).
  • #157
I agree with your last two posts. Thanks @Morbert! :smile:
As an aside, it seems to me that Barandes's formulation does not necessarily imply an ontology where the configuration of the system is defined at every instant. Therefore, I believe the formulation is compatible with an interpretation based on sparse events, such as relational quantum mechanics. I think something like this could alleviate the difficulties some may have with the fact that, although the configuration takes a defined value at every instant, there is no continuity, so particles could "jump" between division events, as we have already discussed in relation to the double-slit experiment.
(edit): I just noticed that in the last section of this recent paper, Barandes says:
"This interpretation has a thoroughly realist orientation, and does not entail parallel universes, nor does it involve perspectival or relational notions of ontology." :confused:
Lucas.
  • #158
I think it explicitly does!
But this ontology is understood differently, the same thus goes for that there is a definitey history also.
But there exist no global realist phase space that can encode the union of all subsystem histories consistently without destroying interference. The "realist perspective" of Baranes is more that the world can be understood as a union of "real" subsystems, that are as real as anything gets, and have definite histories - BUT when you put these things together in a causally local way you arrive at a system exhibiting quantum interference, but it seems to give a new understanding to causation. There is no univeral causation in terms of initial state -> future state. Barandes formulation suggest that there is only a universal stochastical constraints that determines how parts of the sytem interact stochastically with other parts.
So I think Barandes moves the "weirdness" of an entagled system, like we ask what IS IT, to saying that all the entagled parts are not "complex" they are just real stuff, but he suggest new dynamical laws, that constrain the stochastics of the parts.
[Edit: paragraph removed at poster's request.]
/Fredrik
  • #159
Fra said:
And of course that this is equivalent to the simple dynamics in hilbert space, but instead we get a "werid ontology" because noone understands what a hilbert space is.
(edit: On re-reading the last paragraph I see it seems to add nothing not already said above, so i removed it, no need to rephrase. )
I apparently forgot to remove it, in despite of me writing I did, and now the edit option is gone 🙄
/Fredrik
  • #160
/Fredrik
I just used magic moderator powers to edit the post and remove that paragraph. Please take a look and make sure I did it right.
  • #161
Thanks Peter, that looks better. Sorry for the mess.
/Fredrik
  • #162
As an aside: Barandes derives a "dictionary" form for transition maps $$\Gamma_{ij}(t\leftarrow 0) = \mathrm{tr}P_i(t)P_j$$I anticipate post-selected transition maps of the form $$\Gamma_{ij}^{k,t'}(t\leftarrow 0) = \frac{\mathrm{tr}P_i(t)P_j P_i(t)P_k(t')}{\mathrm{tr}P_k(t')P_j}$$for systems with a division event at ##t'## with post-selected outcome ##k##, and ##0 < t < t'##. This would be analogous to the way the Aharonov–Bergmann–Lebowitz rule gives us probability distributions for post-selected experimental runs, and would imply the particle does not jump across slits immediately prior to which-slit detection in the two-slit experiment.
But I can find no such map in literature so it's only speculative on my part.
  • #163
I think it's possible to distinguish the stochastic-quantum correspondence theorem from an interpretation based on a specific ontology. Barandes favors an interpretation of the formalism where there is a configuration of the system for each instant in time, but I don't think that's the only option. Personally, assuming that the fundamental role is played by stochastic transitions between configurations at different times, I find it easier to accept an ontology in which configurations are defined only at the times when systems interact.
Lucas.
  • #164
Morbert said:
As an aside: Barandes derives a "dictionary" form for transition maps Γij(t←0)=trPi(t)PjI anticipate post-selected transition maps of the form Γijk,t′(t←0)=trPi(t)PjPi(t)Pk(t′)trPk(t′)Pjfor systems with a division event at t′ with post-selected outcome k, and 0<t<t′. This would be analogous to the way the Aharonov–Bergmann–Lebowitz rule gives us probability distributions for post-selected experimental runs, and would imply the particle does not jump across slits immediately prior to which-slit detection in the two-slit experiment.
Interesting! I suppose that, given the stochastic-quantum correspondence, such post-selected transition maps should also be valid in Barandes's formulation. In any case, I was referring to the case without a which-slit detector, but rather to a conventional double-slit experiment (source, slit wall, screen).
Lucas.
  • #165
Lucas.
What is your preferred kind of interpretation mayI ask? I agree don't think Barandes' formulation talks about things when measurement device is there so it doesn't compel a specific perspective deeper ontologies. I may think some make more sense than others but I don't think the formulation can tell you anything about that on its own.
  • #166
iste said:
I agree don't think Barandes' formulation talks about things when measurement device is[n't] there
While it does not talk about the trajectory beyond what is minimally implied by the transition maps, it does commit to an ontology. At all times (even between measurements or in the absence of any measurement) the system has a definite configuration in a standard configuration space.
  • #167
Personally, I prefer an interpretation/formulation like relational quantum mechanics.
Lucas.
  • #168
I wonder how Barandes' interpretation deals with some recent no-go theorems, such as this work by the Cavalcanti group. It gives up locality assumption?
Lucas.
  • #169
Can you source this in his papers?
  • #170
Lucas.
I would say that indivisibility would be closest to the violation of absoluteness of observed events.
  • #171
I agree, but I think there seems to be a natural possible ontology associated to Barandes view.
That said, I agree in the sense that I see Barandes ontology as an "effective ontology" in that my preferred personal view is that barandes ontology of corresponds to an emergent steady state of an underlying evolutionary process with a more fundamental ontology, that is not unistochastic. I see unistochasticity as posisbly associated to a steady state in a more wild stochastic (corresponding to a yet unkown theory). But for dicussion I try to distinguish that from Barandes ontology to avoid misunderstandings, but sometimes I forget that and entertain two levels of ontology in the discussion.
Lucas.
As iste mentions already but the "Absoluteness of Observed Events" in that paper makes absolutely not sense in Barandes view.
The division events of subsystems are not objective, ie there is no superobserver which can hold them. They are sort of relative to a subsystems, and they make not sense if you try to form a naive global joint probabilities, because all the perspectives contain a physical tension, which is manifested by quantum interactions and inteference.
I also think that the initial ambition of RQM is conceptually sound but for me the glitch in the logic is when Rovellis first acknowledges that there are no absolute relations between observation. This is even conceptually related to the indivisibility of stochastics, which is not absolute. Then Rovelli tries to "solve that" by saying that the different observations can only be compare via physical interaction. Sometime I also agree with. The problem is when he just identifies this with quantum mechanical interaction. This completely evades the first principle reconstructtion that I expected, so it has not explanatory value to me, it may be more similar to a sort of "correspondence" as well in a way.
/Fredrik
  • #172
Rather than postulating Hilbert spaces and their ingredients from the beginning, one instead posits a physical model, called an indivisible stochastic process, based on trajectories in configuration spaces following generically indivisible stochastic dynamics.
As with a traditionally defined dynamical system, each such mathematical structure describes a physical
system moving deterministically or stochastically along some trajectory in a configuration space, albeit with a
more general set of laws than according to standard definitions.
Seen from another point of view, this stochastic-quantum correspondence yields an alternative way to formulate quantum theory, in the language of trajectories unfolding stochastically in configuration spaces.
This correspondence has the potential to deflate and demystify many of the exotic features that are usually associated with quantum theory, with superpositions no longer describing a literal smearing of physical configurations, and with measurements demoted to just an ordinary kind of stochastic interaction.
  • #173
I can't comment directly until I've read that paper properly. I'll just make some general comments:
Re/ Locality: The formalism should always strictly adhere to the principle of causal locality laid out in the new prospects paper. If this work brings tension with locality, it would be a different notion of locality.
Re/ Wigner's Friend scenarios: Under this interpretation, a superobservation will not erase events that have already occurred. Ontologically speaking, Wigner's friend still recorded a definite outcome in the lab. Instead what a superobservation does is erase any record of these events, such that the events that occurred do not condition the state of the system after superobservation in any way. The memories Wigner's friend will have after the superobservation (assuming he survives it) will bear no relation to what actually happened in the lab.
  • #174
Morbert said:
I
But it does not give a complete characterization of quantum mechanics without the measurement device as a subsystem of the indivisible stochastic process.
  • #175
I have no idea what this is a response to.
  • #176
Before I comment or agree I wonder what you refer to with "complete".
If you mean there is no charcterization of measurements without external reference, then I agree. This is the unpalatable part of QM in the first place. The correspondence does not change this IMO.
But this imo maps onto the missing first principle construction of the stochastic contraints and gamma. Which requires new hypothesis.
Barandes gets us a correspondence and leaves the rest for future ideas i suppose.
And it offers us nice new perspective that any new hypothesis can reproduce, instead of hilbert stuff.
/Fredrik
  • #177
Your previous post to me. It just seems clear to me that is the indivisible approach cannot account for all the information in the quantum theory it is being translated to without evoking the measurement device, it doesn't make sense that the theory that can be talking about stuff in the external world when it is not interacting with a measurement device. Any further extrapolation is extra-theoretical interpretation, and not inside the theory itself.
  • #178
/Fredrik
I mean  incomplete in the sense that Barandes says that the indivisible stochastic process cannot account for the phase in the quantum theory it is being translated to unless the measurement device is explicitly incorporated into the stochastic process. The stochastic process of the atuff you are measuring is inextricably connected to the measuring device. Its not a theory of stuff in the world free-floating around, its a theory of what happens when you measure stuff. It doesn't talk about anything else without adding your own extra interpretation. That shouldnt be a surprisse if that is widely considered the same for quantum mechanics in general and this is just a translation between the two theories. Why should it contain any extra-information not apparent before when the dictionary relates the two theories by modulus-square which doesn't seem anything new fundamentally?
The real nice content of the formulation is that it tells you that the wavefunction has no ontological meaning and just carries information about the statistics of the world when you measure it. It is a perfect instrumentalist theory.
  • #179
That's possible. However, absoluteness of observed events is closely related to a certain kind of relationality, and Barandes says: "This interpretation has a thoroughly realist orientation, and does not entail parallel universes, nor does it involve perspectival or relational notions of ontology."
Lucas.
  • #180
There are some interesting papers ("Quantum theory from rules on information acquisition" and Quantum theory from questions) that derive quantum mechanics from principles closely related to Rovelli's formulation. However, they do not go beyond a reconstruction of the formalism.
Lucas.
  • #181
Lucas.
They say in the article that formally-speaking the absoluteness assumption implies assumption of joint probability, which is the kind of assumption also violated in indivisibility. But I think the breakdown of this joint probability distribution would be cashed out in terms of mutually-exclusive measurement contexts that cannot occur at the same time, so yes, I guess one could say instead that the relationist perspective utilizes talk about joint probabilities that can be talked about in some other alternative way where there is not simultaneously different perspectives (and which is not inherently tied to the indivisibility approach).
  • #182
  • #183
I don’t think Barandas specifies the origin of the contingent ingredient in his stochastic–quantum correspondence. For that you would need something like this.
https://doi.org/10.5281/zenodo.15603882
  • #184
Lucas.
Just skimming the abstracts, the ideas in those papers certainly related to alot of my preferred thinking, with some differences. I see good things in many interpretations, RQM, Qbism and also Barandes. The relational notion for is also natural since any inference, or "information aquisition" is necessarily contextual or "relative" to the host system (which i think of as the agent) as the possible inferences and information encoding are constrained (but sometihng, requiring some additional hypothesis tough).
As they say in the abstract of the first paper
"from rules constraining an observer’s acquisition of information about physical systems"
So i see good things in many interpretations. But there are also some interpretations that never made much sense at all to me, this is for example mwi and also some of the objective collapse theories whose beauty or point I never got.
But given all this, there are MORE problems to solve than just QM, that for me also changes the preferences. This is for example fine tuning issues and understanding the hierarchy of interactions. The pure reconstructions gives us no insighs into this. I like Barandes because it gives a good handle, to the ABM perspective of things. Fine tuning comes from considering the set of all possible "constraints" of the observers/agents information processing. This must be tamed, or the theory space till diverge.
/Fredrik
  • #185
I can't do much with "It just seems clear to me." but I am happy to respond to some substantive concern.
  • #186
I don't understand what you mean, I have just pointed at a fact about the theory that it requires the measurement device as part of the indivisible stochastic process in order for it to produce quantum mechanics. If the theory described things when they were not being measured, this would not be the case. Its very simply.
In contrast, you just provided a list of quotes which amount to the kind of vague assertions you find in the introduction of discussion of a paper without pointing to some specific fact or feature of the theory for justification. You clearly don't want to actually analyze this point or demonstrate a more tangible justification of your beliefs so I don't understand why you initiated this exchange.
  • #187
Is this good or bad in your opinion? (I ask to understand if what you wrote is intended as a clarification or critique of Barandes picture?
I personally think no agent or context can make any inference about anything without physical interaction. So that the context becomes deeply evolved with the "black box" is rational and unavoidable. This involes backreactions. On the contrary i would be sceptical about rhe opposite. Ie a theory claiming we can know and learn things without stepping into the game.
But I am not sure of this was related to your objection or clarification?
/Fredrik
  • #188
Lucas.
I you like those, there is also papers like this, which focus not only logical constructions but more inductive or algorithmic constructions, with addresses the emergence.
Law without law: from observer states to physics via algorithmic information theory, Markus P. Mueller​
https://arxiv.org/abs/1712.01826
That paper has an excellent perspective, but as the real thing is bound to be alot more complex, ever paper so far are more like sort of toy models. So the gap to connecting to SM phenomenology is huge. But there are useful ways of thinking.
Here one can loosely associate subsystem ~ agent, making inferences about its environment, and this whole inteactive game gives emergence of laws. I personally also see common traits with this
Precedence and freedom in quantum physics, Lee Smolin​
Where one can conceptually can associate precedene as beeing mediated by a kind of universal induction (by agents/subsystems).
All these ideas, brought together, and especially if you add Barandes corresondence and some of Rovellis ideas, to me at least, all indicate a common direction. Bot the connection to the logical correspondences, requiest extending them. But I find Barandes unistochastic to be more readily extendable, as it woul be natural to start by relaxting unistochasticy, in order to later recover it.
/Fredrik
  • #189
/Fredrik
Nevermind, after thinking about it and looking at Albert's document I can see how my revised view was the wrong picture and can see how the stochastic process describes stuff between measurements but obviously in its limited and constrained way. Nonetheless, from my perspective, the reason the stochastic process looks like it does is still because measurement disturbance stops you from inferring more information about the system at those times given some conditioning time (because measurement causes the division events and reset of the process if im not mistaken), rather than a description of the system unfiltered by epistemic limitations.
Because of my realist inclinations, I find the "black box" perspective undesirable. I would like to see measurement distrubance not as an inherent aspect of knowledge generally but due to some specific physical property of the universe which diminishes as we move to larger scales. While the stochastic realizations between measurements would be existing objectively, they should not reflect a true God's eye perspective on the dynamical evolution, because God is going to see the actual underlying trajectories and is going to have access to their underlying chains of conditional probabilities that are due to fluctuations / randomness (at least at some level of coarseness) in the physical description rather than epistemic uncertainty. The quantum perspective on the other hand would only telling us what measurements allow us to see or infer, rather than the God's eye view.
(Edited for my own clarity approx. 4hrs later)
  • #190
Thanks, this clarifies things and now I understand your preferred perspective, even if it is different than mine.
/Fredrik
  • #191
My perspective that that the "knowledge" of the black box is encoded in the physical microstate of the inferrer. So knowledge for me has a physical basis. But if one associates microstates of autonomous subsystems, then this locally, buy physically encoded "knowledge" take the form of subjective HV/beable.
So I distinguish between what is real and what is inferrable. Things that "just is", without beeing inferred, like subjective beables, are defined with respect to the "self". Ie. the subsystems real configuration (basic ontology), is real, and represents the knowledge, but other subsystems try to infer this, they can't just grab it from some shared global memory. And this "inference" is the actual physical interaction, ie the quantum interaction.
This how I see this, this entangled situation is not a "problem" in my view, my problem is rather how to determine the form of the microstructure ontology and thus it must also constrain the inferences allowed(in the spirit of the paper#1 in post 180). This is the open problem I see. But Barandes perspective is giving a fresh perspective, although it does not solve the problem.
/Fredrik
