Understanding Magnet Wire: Differences and Uses
  • Thread starter Thread starter eq1
    Magnet Wire
Magnet wire is a type of insulated solid copper wire specifically designed for use in inductive devices like transformers and motors. It features a thin polymer film insulation that can withstand high temperatures, up to 250°C, which prevents melting and short circuits in heated environments. The thin insulation allows for closer coupling between conductors, which is crucial in transmission line applications. Magnet wire can come with different types of enamel coatings, some allowing for direct soldering while others require scraping before soldering. Understanding these characteristics is essential for proper application in electrical engineering projects.
eq1
What is "magnet wire"?
I have a test procedure I am trying to follow and it calls for "two strands of twisted magnet wire." I know it is referring to something like this:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXHZW4&P=FR
I know the transmission line characteristics of twisted wire and why one would do this when making a measurement but my question is: What makes "magnet wire" different from common insulated solid copper wire? This is the first time I ever saw this magnet wire term.
I looked at this page:
http://en.wikipedia.org/wiki/Magnet_wire
And it seems like this is just a colloquial term for insulated solid copper wire because people often use this wire type when making various inductive devices despite all the details in the wikipage. Is this right or am I missing something important? If so, I get the abbreviation because insulated solid copper wire is a mouth full and repeatedly typing it kind of sucks too.
The second article from wikipedia really describes it well. Magnet-wire has a polymer film insulation that can withstand 250C temperatures which while high is the heated environment in a transformer winding and ordinary plastic insulation would melt causing an unwanted short.
One advantage is the insulation is very thin - so for a transmission type experiment, the physical distance between the conductors may be critical to the effect being studied - i.e. the conductors will be very closely coupled.
Got it. Thanks for the replies guys.
Wire for winding transformers and magnets would usually be 'enameled'. The insulation can cope with quite high temperatures and it packs tightly. You can either get it with an enamel which allows you to solder to it directly ('self fluxing' iirc) or a tougher enamel which needs to be scraped off (one brand name was Lewmex, I think). As it happens, I bought some of this the other weekend.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
