Understanding Newton's First Law of Motion in Physics
Newton's first law of motion states that a particle remains unaccelerated if the vector sum of all forces acting on it is zero, but this is only meaningful with respect to an inertial frame of reference. The discussion highlights that while Newton's first law applies in inertial frames, it does not hold for photons, which always move at the speed of light and require special relativity for accurate description. Concerns were raised about the applicability of Newton's laws at high speeds, particularly regarding mass constancy and the third law's limitations. It was clarified that Newton's first law remains valid even in relativistic contexts, while the third law can encounter issues, especially with electromagnetic forces. Overall, the conversation emphasizes the importance of context and reference frames in understanding Newton's laws.
Meson080
The below sentence has been extracted from the book-Concepts of Physics 1-H C Verma:
Newton's first law of motion: If the (vector) sum of all the forces acting on a particle is zero then and only then the particle remains unaccelerated (i.e, remains at rest or moves with constant velocity).
Won't the sentence be complete if its mentioned, with respect whom the particle remains at rest or moves with constant velocity?
Science news on Phys.org
Any inertial frame will do.
Yes, you are correct. The statements "remains at rest" and "moves with constant velocity" are meaningless without a frame of reference.
And if "all the forces" includes inertial-forces, non-inertial frames work too.
Newton's first law of motion: If the (vector) sum of all the forces acting on a particle is zero then and only then the particle remains unaccelerated (i.e, remains at rest or moves with constant velocity) with respect to an inertial frame.
I hope the above statement makes sense, does it?
Does the Newtons first law hold good for particles "photons"?
Yes, makes sense to me.
Photons are always moving at speed C with respect to a local frame. Newton's laws do not apply to photons. At high speeds, Newton's laws must be replaced with special relativity.
Doc Al said:
Photons are always moving at speed C with respect to a local frame. Newton's laws do not apply to photons. At high speeds,Newton's laws must be replaced with special relativity.
I am not happy with just one letter "s" in your word Newton's law"s". It made sense to me to say that Newton's second law doesn't hold good for higher speeds, because of not considering mass to be constant. But, why doesn't Newton's first and third law hold good for higher speeds?
In the Book "Concepts of physics by HC Verma", those kind of problems are mentioned in a fixed inertial frame unless mentioned otherwise. Simple.
Newton's first law is fine, even in relativity. Newton's third law has problems, even non-relativistically. (Consider electromagnetic forces.) But when generalized to conservation of momentum, it's fine.
