How Can a Single Component Reproduce Billions of Sounds?
  • Thread starter Thread starter physior
    Sound
Sound production relies on the ability of speakers to reproduce complex waveforms through vibration. A single speaker can create billions of sounds by generating composite waveforms, which are the result of combining multiple sound frequencies. The speaker diaphragm moves in response to electrical signals, accurately matching the waveform of the desired sound. This process allows the speaker to produce sounds like a lion's roar and a bird's chirp simultaneously, even though it operates as a single source. Understanding this concept involves recognizing the relationship between time and frequency domains in sound analysis.
physior
hello!
can you explain me please in few simple words, how are we capable to produce sound?
in nature, a great variety of different things produces different sounds
from the wind on the leaves of the trees, to the huma larynx, a complex organ with numerous muscles
yet, all of these sounds, can be produced from your speakers
what exactly component is able to produce all these billions of sounds?
is it a membrane that gets hitted with different areas of it? or specific properties electricity runs through it?
but how can ALL sounds be produced from that single component?
thanks!
Look at this diagram for a second.
Pretend the top left wave is a lion's roar, and the bottom left wave is a bird's chirp.
These two waves add to each other, and are equivalent to the right wave.
If a speaker can accurately reproduce the right wave, we will hear a lion's roar and a bird's chirp at the same time.
You can add as many waves together as you want. (such as a 100 piece symphony)
Here are some more examples of additive wave synthesis:
Likes Drakkith
how can a speaker reproduce so many (billions) of different waves? (not at the same time)
As long as the speaker can vibrate at a frequency higher than the bird's chirp (maybe 5,000Hz), the speaker can represent that sound. (though if it needs to represent rich sounds faithfully, it will need to be able to vibrate higher)
It simply vibrates to exactly match the waveform on the right. How it does so is directly a result of how much voltage it is given over time.
So, that right waveform is an actual graph of the voltage passed to the speaker magnet over time.
It also happens to be an actual graph of the position of the speaker diaphragm (in very small distance units) as it moves in and out, making sound.
I think you are missing the point that the speaker doesn't vibrate at all those different frequencies, it vibrates at a COMPOSITE frequency and produces exactly the same thing that you ear gets when it is listening to all those things happening at the same time.
To expand: The human ear hears a lion roar and a bird chirping at the same time. These events separately cause sound waves but when they impinge on the ear, what they create is a composite waveform. You only have one ear drum on each side after all. The speaker just produces that composite waveform from a single source rather than from multiple sources, but it is still one waveform, it just has the composite characteristics of multiple waveforms.
When you study Fourier Analysis, you'll learn more about this.
Likes davenn
The sound that a microphone picks up is just a variation of pressure. This is a single quantity, varying in time which, to suit Engineers and Scientists, can be analysed in terms of the sum of many pure sinusoids at different frequencies. A loudspeaker, fed with exactly the same signal that the microphone picks up, will produce the identical sound by making the air move in exactly the same way. It is only necessary that the speaker cone can be made to move as required. It has to be light and rigid enough and to be driven with the appropriate force (from the coil and the magnet). It doesn't 'know' that it is emitting all those separate waves because that's just a way of looking at it.
The Time Domain and the Frequency Domain are just two ways of describing the same complex signal.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
