Understanding Srednicki's 7.14-7.16 Equations: G(t-t') and the RHS of f(t)
  • Thread starter Thread starter koolmodee
    Srednicki
koolmodee
\intdt' G(t-t') f(t') = 1/i \delta/\deltaf(t)
where G(t-t') = i/ 2w exp (iw (t-t'))
I thought the RHS of the first equation is f(t). Can someone explain?
thank you
This doesn't make sense, and I'm not sure where you got it. Something like it that is correct and that is used to get the 2nd line of (7.16) is
{1\over i}{\delta\over\delta f(t_1)}\left[{i\over2}\int dt\,dt'\,f(t)G(t-t')f(t')\right] = \int dt'\,G(t_1 -t')f(t').
Well, I thought what I write was implied in the equations in the Srednicki book.
But then I don't see how we get from the first line two the second in 7.16. with your equation.
Is the term in the brackets equal to one? And you mean t_2 instead of t_1, right?
What you wrote does not make sense. The functional derivative on your right-hand is not acting on anything.
Let
Z(f)=\langle 0|0\rangle_f
From 7.11,
Z(f)=\exp K(f)
where
K(f)={i\over 2}\int dt\,dt'\,f(t)G(t-t')f(t')
By the chain rule,
{\delta\over\delta f(t_2)}Z(f)={dZ\over dK}\;{\delta\over\delta f(t_2)}K(f)
and since Z=\exp K, dZ/dK = \exp K = Z. Now we use
{1\over i}\,{\delta K(f)\over\delta f(t_2)}=<br /> {1\over i}\,{i\over 2}\int dt\,dt&#039;\left[\left({\delta f(t)\over\delta f(t_2)}\right)G(t-t&#039;)f(t&#039;)+f(t)G(t-t&#039;)\left({\delta f(t&#039;)\over\delta f(t_2)}\right)\right]
{}\qquad\qquad={1\over 2}\int dt\,dt&#039;\Bigl[\delta(t-t_2)G(t-t&#039;)f(t&#039;)+f(t)G(t-t&#039;)\delta(t&#039;-t_2)\Bigr]
{}={1\over 2}\int dt&#039;\,G(t_2-t&#039;)f(t&#039;)+{1\over 2}\int dt\,f(t)G(t-t_2)
{}=\int dt&#039;\,G(t_2-t&#039;)f(t&#039;)
where, to get the last line, we use G(t-t_2)=G(t_2-t), and change the dummy integration variable in the 2nd term from t to t&#039;, so that it is then the same as the first term.
thank you!
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
