Understanding Water Pressure: Solving Homework with P1 and P2 Equations
The discussion revolves around understanding water pressure using the equations P2=P1+pgh and pressure=force/area. Participants are attempting to solve a homework problem related to pressures in two chambers.
  • Participants are discussing how to apply the pressure equations, with some suggesting direct substitutions and others questioning the reasoning behind specific calculations. There is an exploration of how to rearrange formulas to find unknowns.
The discussion is active, with participants offering different approaches to calculating pressures in the chambers. Some guidance has been provided regarding the use of the formulas, but there is no explicit consensus on the correct method or final answer.
There is mention of known values such as the pressure in chamber 2 and the area of chamber 1, but the completeness of the information and assumptions made in the problem setup are not fully clarified.
yesshh
P2=P1+pgh
I thought you would just plug in the pressure in pascals to p1 and add [(1000 kg/m3)(9.8m/s2)(sqrt 2)]?
Okay find out the pressure in chamber 1. Pressure=force/area.
Did this help?
So the answer is just 1.3x10^5 divided by 2?
Why?
No, 1.3x10^5 is pressure in chamber 2. Use the formula given to you in the question to calculate the pressure in chamber 1. You know the area of chamber 1 and you have calculated the pressure for chamber 1 so rearrange the formula pressure=force/area to give you the force.
