Unfortunate Doppler Discussion in Nice Paper
PAllen
In another thread, Dalespam posted this paper:
http://arxiv.org/abs/gr-qc/0311038
The paper is, overall, very nice and introduces a very convenient unification of all coordinate systems for the spherically symmetric vacuum GR solution that manifest the static character ( of the exterior geometry) as well as the spherical symmetry.
However, there is a discussion of redshift on page 6, that deserves a cautionary statement. The authors sum up a calculation as follows:
"The redshift formula is directly obtained from this ratio;
since it doesn’t depend on the choice of time coordinate,
it holds for all variations on the general line element.
Thus, the redshift is infinite if the emitter is located at
r1 = 2M, even if the coordinate system allows for a crossing
of the event horizon in finite time."
I have the following issues with this summary:
1) The calculation only shows the well known result that redshift between two static observers approaches infinite as you pick one of them closer and closer to the horizon (if you imagine one of them moving, you no longer have a static observer, and the given formula no longer suffices, by itself).
2) There is no such thing as redshift from light emitted at the horizon and received by a static observer. The light is trapped, pure and simple.
3) Between two static observers, the formula is reversible and indicates blue shift for radially ingoing light. Again, though, there can be no static observer to detect infinite blueshift.
4) Instead, any observer receiving light at the horizon from an exterior static observer must be following a time like path, and, depending on the path, will receive a finite shift that can be any amount in the red or blue direction.
In sum, I find this statement by the authors exceedingly misleading, even dead wrong. I think they know this, and it is just careless editing.
I noticed this too, and I agree with your criticisms.
One other thing I noticed was the use of the term "static" without ever qualifying it, which of course is open to all kinds of misinterpretations. :wink: It's obvious from their line element that it is *not* static, or even stationary, at r <= 2M, since the \partial / \partial u Killing vector field is no longer timelike, but they never discuss that or even point it out.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
According to the General Theory of Relativity, time does not pass on a black hole, which means that processes they don't work either. As the object becomes heavier, the speed of matter falling on it for an observer on Earth will first increase, and then slow down, due to the effect of time dilation. And then it will stop altogether. As a result, we will not get a black hole, since the critical mass will not be reached. Although the object will continue to attract matter, it will not be a...
