Uniform accelerated motion problem help
A person on an overpass needs to time the drop of a package onto a truck accelerating at half the speed of gravity, starting from rest 100 m away. The truck takes less time to reach the point directly below the overpass than initially calculated, with the correct time being approximately 3.87 seconds. The package takes 2.5 seconds to fall 30 m, so it must be dropped before the truck arrives. The error in the initial calculation was due to misapplying the kinematic equations for the truck's acceleration. Proper timing is crucial to ensure the package lands on the truck as it passes beneath the overpass.
DB
im stuck on this one:
a person standing on an overpass above a roadway wishes to drop something onto a truck. the truck starts from rest and accelerates at half the speed of gravity from a position 100 m from the point of impact. the overpass is 30 m above the truck. how long after the truck started should the person wait before dropping the packgage? (gee = 10 m/s^2)
okay so basicallly wat I've got is this: the truck will take 20 seconds until it is perfectly lined up with the overpass;that being the point of impact. i also got that it will take 2.5 seconds for the package to travel 30 m accelerating at gee.
the answer is approx 3.9 secs but i don't know how to come to this, have i done something wrong?
DB said:
okay so basicallly wat I've got is this: the truck will take 20 seconds until it is perfectly lined up with the overpass...
There's your error.
Check your arrithmetic again. Didi you use the correct formula ?
I got Δt = 3.87 sec
Note that if the person drops the package when the truck is directly beneath them, the package will hit the ground long after the truck has passed. You need to drop it a certain amount of time before the truck reaches directly beneath you. Also, your time for the truck to reach you is too high (remember, it is accelerating).
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
