Uniform Circular motion problem,
The discussion focuses on calculating the centripetal acceleration of wind moving in a circle at a distance of 25 km from a hurricane's eye, with a velocity of 180 km/h. The correct formula for centripetal acceleration is Ac = V^2/r, but the initial calculations were incorrect due to unit inconsistencies. Participants emphasized the importance of converting all measurements to the SI system (meters, kilograms, seconds) to achieve accurate results. After converting the velocity to meters per second and the radius to meters, the correct centripetal acceleration was confirmed to be 0.10 m/s². The conversation highlights the significance of unit conversion in physics calculations.
naham1866
1. At a distance of 25km from the eye of a hurricane, the wind is moving at 180km/h in a circle. What is the magnitude of the centripetal acceleration, in meters per second squared, of the particles that make up the wind?
Ac=V^2/r = 4∏^2r/T^2 = 4∏^2rf^2
Ac=V^2/r
The answer is 0.10m/s but I just can't seem to get it right.
Ac=V^2/r
You have the right equation in your attempt. Fill in the numbers for velocity V and radius r, and be sure to stay consistent in your units. Show us that work...
Okay so I got Ac=180km/h^2/25km
Problem is that it doesn't give me 0.10m/s
You need to fix the units. You need to convert everything into meters, kilograms and seconds (the mks standard SI system of units). If you mix units like seconds and hours up, you won't get the right answers.
So convert everything you are given into mks units, and plug those quantities into the equation. Carry units along in the equation, and if you have the same units in numerator and denominator, you can cancle them out. Like m/m = 1, and s^2/s = s, and so on.
Now show us what you get...
Haha YES! I Did it! I went out and on my way back home I remembered that I had to change from kilometers to meters, so here's what I did.
180km/h / 60 = 3m/min /60 = 0.05m/s
25km / 1000 = 0.025m
Ac = V^2/r
Ac = 0.05m/s^2/0.025m
Ac= .10m/s
YES! :D
Thank you vey much for the help
You are welcome. Learning to carry units along in your calculations is a huge trick, IMO. I still remember the first time I learned that wey back in undergrad many years ago.
