Uniform Convergence of a Sequence of Functions
The discussion revolves around proving the uniform convergence of the sequence of functions f_n(x) = (x^2 + 1/n)^(1/2) to |x| on compact subsets of ℝ and throughout ℝ. Initial attempts at the proof highlight that while pointwise convergence is established, uniform convergence requires a more rigorous approach using the supremum of the difference |f_n(x) - |x||. Participants suggest employing the definition of uniform convergence and the squeeze theorem to demonstrate that the supremum approaches zero as n increases. The conversation emphasizes the need to analyze the behavior of the functions for different intervals of x, particularly for |x| < 1 and |x| ≥ 1, to complete the proof. Overall, the focus is on clarifying the steps necessary to establish uniform convergence rigorously.
BrainHurts
Define
f_n : \mathbb{R} \rightarrow \mathbb{R} by
f_n(x) = \left( x^2 + \dfrac{1}{n} \right)^{\frac{1}{2}}
Show that f_n(x) \rightarrow |x| converges uniformly on compact subsets of \mathbb{R}
Show that the convergence is uniform in all of \mathbb{R}
Not quite good at these epsilon proofs, not sure if it needs to go that far but by the root law we have that
\lim_{ n\rightarrow \infty} \sqrt{x^2 + \dfrac{1}{n}} = \sqrt{x^2 + \lim_{n \rightarrow \infty} \dfrac{1}{n}} = \sqrt{x^2} = |x|. Now this shows that f_n converges uniformly in some subset of \mathbb{R} correct?
Well, this only shows that the ##f_n## converge to ##|x|## pointswise. You need some extra argument to show or disprove uniform convergence.
Well I suppose we should then go to the definition right.
Let \epsilon &gt; 0, I need to find the right N(\epsilon) such that whenever n\geq N, we have that
\left| \sqrt{x^2 + \dfrac{1}{n}} - |x| \right| &lt; \epsilon.
So I have a hard time messing with that
any hints?
Well, you need to prove
\textrm{sup}_x |f_n(x) - f(x)| \rightarrow 0
So I would start by calculating this supremum. Maybe try the usual techniques of calculus?
Likes 1 person
Just to be clear, I need to find the
\lim_{n \rightarrow \infty} \text{sup}_{x \in \mathbb{R}} | f_n(x) - f(x) | and show that as n \rightarrow \infty then |f_n - f(x) | \rightarrow 0
You need to show this limit is ##0## by definition of uniform convergence. Do you see why.
No, that would just be pointswise convergence.
Thanks, I think I'm going to have to think about this a little while
Let me give you a hint: |x| = sqrt(x^2).
BrainHurts said:
Define
Use the hint, and show that convergence is uniform on an arbitrary compact subset S of \mathbb{R}.
Note that every f_n is continuous, and f is continuous, so that g_n = f_n - f is continuous, and that 0 &lt; g_{n+1}(x) &lt; g_n(x) for every x \in \mathbb{R} and every n \in \mathbb{N}.
Sorry to bring up old news but I haven't really thought about this problem since, but anyway, pasmith all I'm getting from you is that g_n is one-to-one.
g_n(x) = f_n(x) - f(x) = \left( x^2 - \dfrac{1}{n} \right)^{\frac{1}{2}} - |x| = \left(x^2 - \dfrac{1}{n} \right)^{\frac{1}{2}} - \sqrt{x}
So
\lim_{n \rightarrow \infty} \text{sup}_{x \in \mathbb{R}} \left|f_n(x) - f(x) \right| = \lim_{n \rightarrow \infty} \text{sup}_{x \in \mathbb{R}} \left| \left(x^2 - \dfrac{1}{n} \right)^{\frac{1}{2}} - \sqrt{x} \right|
I feel like I need to use the squeeze theorem or something. Am I supposed to use the following argument along the lines of
0 &lt; |g_{n+1}| &lt; |g_n| and as n \rightarrow \infty, |g_n| \rightarrow 0
I assume you intended that last ##\sqrt{x}## to be ##\sqrt{x^2}##, and also I assume you meant
$$\left(x^2 + \frac{1}{n}\right)^{1/2}$$
as in the problem statement.
Try using the fact that
$$\sqrt{a} - \sqrt{b} = \frac{a - b}{\sqrt{a} + \sqrt{b}}$$
assuming ##a## and ##b## are positive.
mmmmmmm OK I'll do that! but yes that's what I meant
Currently working on the same problem for my Intro Real Analysis II course at Rutgers University.
We know ## x^2 > 0 ## and ## \frac{1}{n} > 0 ## for all ##x \in \mathbb{R}## and for all ##n \in \mathbb{N}##, hence using the hint above we obtain $$ \left | \sqrt{x^2 + \frac{1}{n}} - \sqrt{x^2} \right | = \left | \frac{1}{n (\sqrt{x^2 + \frac{1}{n}} + \sqrt{x^2})} \right | .$$
I think we need to split the reasoning for "##f_n## converges uniformly to ##f## on ##\mathbb{R}##" into two parts. Consider ##|x| \geq 1##, which implies ##x^2 \geq 1## and certainly ##x^2 + \frac{1}{n} \geq x^2## for natural number ##n##, hence ##\sqrt{x^2 + \frac{1}{n}} \geq \sqrt{1} = 1##. Moreover, ##\sqrt{x^2 + \frac{1}{n}} + \sqrt{x^2} \geq \sqrt{x^2 + \frac{1}{n}} \geq 1##. Certainly ##n \geq N## gives ## \frac{1}{n} \leq \frac {1}{N}##, so combining these facts we have that $$ \frac{1}{n (\sqrt{x^2 + \frac{1}{n}} + \sqrt{x^2})} \leq \frac{1}{N}$$ for ##|x| > 1##. So setting ##\frac{1}{N} < \epsilon## gives $$\forall \epsilon > 0, \rm{choose}\ N \in \mathbb{N}\ \rm{such\ that}\ N > \frac{1}{\epsilon} \implies \\
\forall |x| > 1 \ \forall n \geq N\ \rm{we\ have}\ \left | \frac{1}{n (\sqrt{x^2 + \frac{1}{n}} + \sqrt{x^2})} \right | \leq \frac{1}{n} \leq \frac{1}{N} < \epsilon. $$
To argue for ##|x|<1##, I am at a loss. Thoughts?
Attempt:
We know ##x^2 < 1##; however ##x^2 + \frac{1}{n} > x^2##.
any hints?
Look at the graph of ##d_n(x) = \sqrt{x^2 + \frac{1}{n}} - |x| > 0##. For any interval ##I## that contains ##0##, what is the value of ##\sup_{x \in I} d_n(x)?##
I don't remember, but in looking at your argument, why don't you include [\itex]|x|\geq 0[\itex]. Secondly, if you're going to do it for x<0, use the definition of |\cdot|, do the same thing, multiply both top and bottom by the conjugate and I think you have what you got. I hope this helps.
  • · Replies 18 ·
  • · Replies 34 ·
