Uniform Probability over Real Line?
The discussion centers on finding the probability density function (PDF) of a laser spinner's projection on a linear scale. The angle X made by the laser is uniformly distributed over –π/2 to π/2, leading to the conclusion that the PDF of Y, the projection on the scale, is f_Y(y) = 1/{\pi}(1+y^2). This result confirms that the transformation from the uniform distribution of X to the distribution of Y is straightforward, despite initial complexities in the approach. The final answer is validated by multiple participants in the discussion.
  • Understanding of uniform distributions, specifically over intervals like –π/2 to π/2.
  • Familiarity with trigonometric functions, particularly tangent and arctangent.
  • Knowledge of probability density functions and transformations of random variables.
  • Basic geometry, including the law of sines and properties of right triangles.
  • Study the properties of uniform distributions and their applications in probability theory.
  • Learn about the transformation of random variables, focusing on techniques for deriving new PDFs.
  • Explore trigonometric identities and their applications in probability problems.
  • Investigate the implications of continuous probability distributions in real-world scenarios.
Students and professionals in mathematics, statistics, and engineering who are working on problems involving probability distributions and trigonometric transformations.
gajohnson
Consider a two-ended laser spinner; that is a pen-like laser acting as the arrow mounted on a pin at the center of a spinner. Suppose the center of the disk is one meter away from a wall of infinite extent marked with a linear scale, with zero at the point closest the center of the spinner and negative numbers to left, positive to the right.
The laser is spun and comes to a rest projecting for one of its ends at a point Y on the
scale (with probability zero the laser will stop parallel to the wall and miss it; we ignore
that possibility). Suppose that the angle X the laser makes to the perpendicular to the
wall is uniformly distributed over –π/2 to π/2. Find the probability density of Y.
The angle at which the laser lands must have PDF f_X(x)=1/{\pi}
That is, it is the uniform distribution over pi radians.
Next, I set up a right triangle and find that the angle opposite the the 1 meter side is equal to {\pi}/2-X and that the angle opposite the base (call it B) is simply X (given by the PDF above). Using the law of sines (and that the distance from the "infinite wall" to the spinner is 1 meter) to find:
B=sinx/sin({\pi}/2-X)
It seems clear to me that Y is then the uniform distribution over lim B as x->{\pi}/2 + - (lim B as x->-{\pi}/2)
This is the entire real number line and so the PDF of Y does not exist.
Is this right (even if my steps are less than rigorous)? Any help would be appreciated.
Let the origin of the Y axis along the wall be the foot of the 1 meter perpendicular side. Then for a point Y on that axis you have ##\frac Y 1 =\tan X##. Try starting with that.
So much simpler! My trig is too rusty.
Ok, so then I find that g(Y)=arctan(Y) and, after taking the derivative, I make the transformation assuming the uniform distribution described before for X.
I get f_Y(y)=1/{\pi}(1+y^2)
Is it that simple? Thanks!
Confirmed this elsewhere. It is indeed that simple. Appreciate your help!
Yes, it is. Sorry I couldn't get back to you yesterday. Too busy.
