de_brook
- 74
Is there a linear space V in which the union of any subspaces of V is a subspace except the trivial subspaces V and {0}? pls help
yyat said:A vector space V can only have non-trivial subspaces if [tex]\dim V\ge 2[/tex].
This means you can choose two linearly independent vectors u, w, which generate 1-dimensional subspaces U, W respectively. Can [tex]U\cup W[/tex] be a subspace? Hint: try to find a linear combination of u,w that is not in [tex]U\cup W[/tex].
de_brook said:I have tried searching for such spaces but i could only find for spaces whose dimension is less than 2.
yyat said:[tex]\dim\mathbb{R}^n=n[/tex], surely you knew that?
ThirstyDog said:I think the short answer is No.
ThirstyDog said:If the dimension of the space is less than two then the only subspace are V and {0} as yyat pointed out. Hence your question is answered in this case.
If the dimension of the space is greater or equal to two then consider spaces X and Y generated by linearly independent vectors x and y. x+y does not belong to [tex]X \Cup Y[/tex]. Implying you can't pick any subspaces and the union will be a subspace.
