Unique Dice Throwing Probability Question
  • Thread starter Thread starter JoshP-hillips
    Dice Probability
JoshP-hillips
G'day,
I've recently been given a probability question to solve and I'm not 100% on my approach towards it.
It goes as follows;
A dice is found to be weighted so that the chance of throwing a 6 is four times the chance of throwing a 1. Chances of throwing numbers other than 6 are equally likely.
a) What is the probability of throwing a 6?
b) What is the probability of throwing a 3?
c) What is the probability of throwing at least a 3?For my approach I'm basically assuming the chance of throwing anything except a six is 1/6, which means the chance of throwing a 6 if 4/6.
So that answers part a) and b), although I feel that the answer is to simple.
And then to answer part c) I just multiply the chances of throwing a 3, 4, 5, 6 independently, and then sum those probabilities. .
Any comments on this approach or help with the question would be greatly appreciated.
JoshP-hillips said:
G'day,
It goes as follows;
And then to answer part c) I just multiply the chances of throwing a 1, 2, 3 and then sum those probabilities. .
What should the sum of the probabilities of all of the possible outcomes be? Is that true in your model?
Well initially I thought the probability would be (1/6)*5 + (4/6) => 9/6
The 1/6 being the chance of rolling a 1-5
The 4/6 being the chance of rolling a 6 (It being 4 times more likely)
But then I came up with a more logical answer;
Probability of rolling a 1-5
x = P(D1-5)
Probability of rolling a 6
4x = P(D6)
BUT => P(D1-5) + P(D6) =1
Therefore;
x + 4x = 1
5x = 1
x = 1/5
So we end up with
P(D1-5) = 1/5
P(D6) = 4/5
So my new answers are
part a) (4/5)
part b) (1/5)
For part c) I've come up with
P(D1-2) = 1/5*2
P(D3-5) = 1/5*3
P(D6) = 4/5
P(at least a 3) = P(D3-5) + P(D6) - P(D1-2)
P(D>=3) = 3/5 + 4/5 - 2/5 = 1
I am on the right track with this?
"A dice is found to be weighted so that the chance of throwing a 6 is four times the chance of throwing a 1. Chances of throwing numbers other than 6 are equally likely."
Your question isn't clearly written. There are two ways to interpret these parts.
a) If p1 = a, then p6 = 4a. If the chances of throwing numbers other than 6 are equally likely is taken directly, this means that also p2 = p3 = p4 = p5 = a as well. If this is true, then it is very easy to find a.
b) If p1 = a, then p6 = 4a. If the second statement applies only the the numbers 2, 3, 4, 5, then all you have from that is that p2 = p3 = p4 = p5 = b, and you don't have enough information to find both a and b.
I will guess you mean the first situation, but you need to be clear about it.
What should ##P(D_6)## be in terms of ##P(D_1)## ?
What should ##P(D_2)## be in terms of ##P(D_1)## ?
What should ##P(D_1)+P(D_2)+P(D_3)+P(D_4)+P(D_5)+P(D_6)## be?
Namaste & G'day Postulate: A strongly-knit team wins on average over a less knit one Fundamentals: - Two teams face off with 4 players each - A polo team consists of players that each have assigned to them a measure of their ability (called a "Handicap" - 10 is highest, -2 lowest) I attempted to measure close-knitness of a team in terms of standard deviation (SD) of handicaps of the players. Failure: It turns out that, more often than, a team with a higher SD wins. In my language, that...
Hi all, I've been a roulette player for more than 10 years (although I took time off here and there) and it's only now that I'm trying to understand the physics of the game. Basically my strategy in roulette is to divide the wheel roughly into two halves (let's call them A and B). My theory is that in roulette there will invariably be variance. In other words, if A comes up 5 times in a row, B will be due to come up soon. However I have been proven wrong many times, and I have seen some...
