Unitary Matrices: Properties & Homework Solutions
  • Thread starter Thread starter Niles
    Matrices
A unitary 3x3 matrix U satisfies the condition UU†=I, where U† is the conjugate transpose. The discussion clarifies that a unitary matrix is not the same as a Hermitian matrix, which requires U=U†. The equality |Un,1|² + |Un,2|² + |Un,3|² = |U1,n|² + |U2,n|² + |U3,n|² is explored in the context of unitary properties. The relationship U†=U⁻¹ is confirmed, emphasizing that this does not imply U is Hermitian. Understanding these definitions is crucial for correctly applying properties of unitary and Hermitian matrices.
Niles
Hi
Is it correct that when I have a unitary 3x3 matrix U, then
|Un,1|2+|Un,2|2+|Un,3|2=|U1,n|2+|U2,n|2+|U3,n|2,
since UH=U? Here n denotes some integer between 1 and 3.
U=U* is called hermitian matrix not unitary, a unitary matrix satisifies: UU*=I.
If you multiply what do you get?
My book says that a unitary matrix satisfies UHU=I, i.e. UH=U-1.
I don't think so. That is not an example of a unitary matrix that is Hermitian. You just wrote the definition of a unitary matrix in another form.
Definition of a unitary matrix: UU^\dagger=I. Then we multiply both sides with the inverse of U, which gives us (U^{-1}U)U^\dagger=IU^\dagger=U^\dagger=U^{-1}.
The definition of a Hermitian matrix is:
U=U^\dagger
note that it is not the same as the equality you wrote in post #3.
Use the definition of the conjugate transpose (A^\dagger)_{ij}=\overline{A}_{ji}.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
