Universal gravitational problem
Planet X has a mass eight times that of Earth, and its surface gravity is 19.6 m/s², leading to the conclusion that its radius is twice that of Earth. The discussion revolves around applying the universal law of gravitation, specifically the formula F = GmM/r², where G is the universal gravitational constant. Participants clarify the distinction between G and g, with g representing gravitational acceleration, which is approximately 9.81 m/s² on Earth. By substituting the known values into the equations, the relationship between mass, radius, and gravitational acceleration is established. Ultimately, the calculations confirm that the radius of Planet X is indeed twice that of Earth.
anna sung
Planet X has a mass 8 times that of Earth and the acceleration due to gravity at its surface is 19.6 m/s2. The radius of the planet x compared to Earth is:
The answer is 2times bigger
Fg = gm1m2 / r^2
Is Earth's gravity 9.8 and the gravity of planet x is 19.6.
Where would I put these values in ?
Check your relevant equation what do each of the variables and constants mean?
In particular, f=Gmm/r^2 where G is what?
Isn't g universal gravitational constant which is 6.67 x 10^-11?
Or is this where the 19.6m/s^2 should go into?
G*m_1 is the acceleration due to gravity for a body
Denote the universal gravitational constant by G. People use the notation g for the gravitational acceleration on the surface of the Earth: g≈9.81 m/s2
According to the law of universal gravitation, the force of gravity on an object of mass m is F=GmM/R2 at the surface of the Earth. M is the mass of Earth (5.97 x 10^24 kg) and R is the Radius of Earth (6.37 x 10^6 m).
The gravitational acceleration is F/m=g=GM/R2. Plug in the data: it is 9.81 m/s2
19.6 m/s2 is the gravitational acceleration at the surface on an other planet. How does it related to the radius and mass of the planet?
ehild
So f=mg=GmM/r^2
Then say the mass of Earth is 2. Planet x is 8 times of the earth, so then 16.
Earth has gravity 9.8 and planet x has gravity 19.6.
Then the equation is really this: g=m/r^2
So Earth is square root ( 2/9.8)=0.45
planet x is square root (16/19.6) = 0.903
Oh, okay yeah and it's twice larger.
Okay I get it,
Thank you so much.^_^
You are welcome :smile:
ehild
