How Does Gravity Work and What Causes Time to Slow Down Near a Black Hole?
The discussion centers on the effects of gravity on time, particularly near black holes, where time dilation becomes extreme due to intense gravitational fields. It highlights that as gravity increases, time ticks slower, and objects moving near light speed further contribute to this phenomenon. The conversation also touches on gravitational redshift, suggesting that larger stars exhibit redshift due to their greater gravity, while smaller stars show blueshift. There is confusion regarding how gravity can exist outside a black hole, as nothing can escape its event horizon, leading to debates about the nature of gravity and its transmission. Ultimately, the discussion emphasizes the need for a deeper understanding of gravity and its implications in the context of black holes and the universe.
temoisio
About relativity of time. It can be noticed already in Earth in vertical time measurements. But how long it continues.
So what will happen in black hole to time. Gravity is unlimited, so ticks will slow down. And other thing, speed slows down the time. So in huge gravity, all speed will increase near light speed, so time would slow down. So from tick perspective, black hole would be the slowest ticker in universe.
How fast is ticking in really empty space. Will it be infinity or something close to our ticking. So what is the distance, that mass and gravity will effect to tick speed (in terms of gravity slowness).
To practical universe measurements. Now universe is widening, as measured with spectrum. But could relative time be big enough in larger scale (calaxy level), that it would effect to measurements? So as idea, it should look the same:
- Timetick speed is slower in calaxy (or a large star), redshift happens?
- Object is moving further, redshift happens
- And vice versa with blueshift and object moving closer
So if we compare example light of the sun to much bigger star, there should be some redshift. As bigger star has bigger gravity, and therefor slower time. But again, smaller star should have bluesift. So directly with this theory, if universe would not widen, all small stars should have bluesift and large stars should have redsift.
Astronomy news on Phys.org
gravitational time dilation is not proportional to gravitational field intesity.
its proportional to gravitational potential
gravitational time dilation becomes infintite at the event horizon even though the gravitational field isn't infinitely strong there.
the rest of your post is incomprehensible gibberish
What?
Ok, actually there is test results now when googled:
"The first observation of the gravitational redshift was the measurement of the shift in the spectral lines from the white dwarf star Sirius B by Adams in 1925. Although this measurement, as well as later measurements of the spectral shift on other white dwarf stars, agreed with the prediction of relativity, it could be argued that the shift could possibly stem from some other cause, and hence experimental verification using a known terrestrial source was preferable ."
"A very accurate gravitational redshift experiment, which deals with this issue, was performed in 1976,[34] where a hydrogen maser clock on a rocket was launched to a height of 10,000 km, and its rate compared with an identical clock on the ground. It tested the gravitational redshift to 0.007%."
Yes, seems it's hard to measure from space, as there are other things effecting (maybe mostly movement).
But yes, this "earth test" was performed in 1976. So I could think there might be some more up to date information.
So i think answer is, that there are no studies those would provide results. And it is thought, that redsift from galaxy light means, it is moving away. Not, that there is time dilation.
Yes, in black hole there is one thing confusing. There are findings written, that near black hole, hole itself can be confirmed, because it's gravity. But gravity itself is particles (or kvarts or waves), those can't travel out from black hole (nothing moves faster then light). So black hole should not have gravity at all.
So only thing black hole could do, is curve the time & space. But again that curving should be as well inside this light speed theory. So if there is a black hole, that should not have any effect to outside. As no force or wave or particle could come out from the black hole.
So time dilation could be only thing that black hole could do. So that would remain even nothing comes out from the black hole.
There can be answer to this if knowing how gravity works more detailed. But I haven't run any explanations about gravity of the black hole.
Huh?
Hunter612 said:
Huh?
Ok. So,
How can gravity travel out from black hole? So:
- Black hole is a huge mass, it creates gravity around it
- Gravity is estimated to be particle or wave (graviton)
So how can black hole has gravity, when graviton should then travel out from black hole?
So some theory is not right :confused:
Gravity is not mediated by real gravitons. Nothing has to escape the event horizon to produce a static gravitational field. Static fields carry no information.
ok, tx. Yes seems wikipedia has some articles around this as well:
http://en.wikipedia.org/wiki/Static_forces_and_virtual-particle_exchange
Then there are theories like string theory:
http://en.wikipedia.org/wiki/String_theory
Yes just time would be easier to believe for now. But again it is estimated, that curving space time moves in speed of light as well. So basically it could not curve out from black hole. Then of course can be, that something happens in event horizon. That you can't actually tell outside black hole, how much mass there is.
But yes, as told in wikipedia, all other forces have been quite much understood, but not gravity. It's there but why.
Say I'm someone without a clue, explain to me what gravity is and how it works.
Yes that's good way to put it. So what's the best guess at the moment what gravity is. Or is there real facts I've not yet found.
So example from good argument:
"The hypothesis is that the gravitational interaction is likewise mediated by a – yet undiscovered – elementary particle, dubbed the graviton, instead of being described in terms of curved spacetime as in general relativity."
http://en.wikipedia.org/wiki/Graviton
Again, like already mentioned, how can that interaction be from mass in black hole to outside, over event horizon.
