Projectile Angle Calculation: Finding Optimal Launch Angles for Accurate Hits
To determine the optimal launch angles for hitting a cliff 170m high and 550m away with a projectile speed of 110 m/s, the problem is broken into x and y components. The horizontal distance (dx) and vertical distance (dy) are analyzed using kinematic equations, with gravity acting on the vertical motion. The relationship between the angles and distances involves the tangent function, where tan(θ) equals the ratio of the horizontal distance to the vertical height. The hint provided, 1/cos2θ = 1 + tan2θ, is not directly applicable to finding the angles in this context. The solution requires using the known distances to solve for the angle θ.
ericka141
You shoot a cannon at a distant cliff. The cliff is 170m high and 550m away, with the launch speed of the projectile being 110 m/s. Wind resistance is ignored. At what angles, relative to the horizontal, should the projectile be shot to hit the target?
Hint: 1/cos2θ = 1+tan2θ
Kinematics Equations:
vf=vi + a*t
d= vi*t + 1/2a*t^2
d= (vf^2-vi^2)/2a
I've broken the problem up into x and y components:
vix= vixcos(θ)
dx= 550m (or vixcos(θ)*t)
ax= 0m/s^2
viy= viysin(θ)
dy= 170m (or viysin(θ)*t)
ay= -9.81m/s^2
I know how to find the maximum distance that a projectile travels when given the initial velocity (or the distance when given the initial velocity and the angle it's shot at) but I'm not sure how to find these angles. I'm not exactly sure where tan(θ) comes in. If somebody could help me with this that would be GREAT, this assignment is due tonight.
If you know x and y (or v_x and v_y), you can find the angle. Who is the man? Tan is the Man!
Recall SOH CAH TOA
Then how would I use 1/cos2θ=1+tan2θ ??
You don't. tan(\theta) = \frac{d_x}{d_y}
Solve for \theta
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
