Urgent Question
  1. Aug 20, 2005 #1
    Hi everyone, there is this question that is really bugging me and i am wondering if you guys could help me out.
    When a certain positive integer N is divided by a positive integer d, tje remainder is 7. if 2N+3 is divided by d, the remainder is 1. Find all possible values of d.
    Pleasse help me with this one, as it is urgent :surprised
  3. Aug 20, 2005 #2
    Zurtex
    N = 7 (mod d)
    2N + 3 = 1 (mod d)
    Substituting:
    2*7 + 3 = 1 (mod d)
    17 = 1 (mod d)
    I wouldn't say it's too hard to work it out from there. If a simple way doesn't occur to you then just check all the values for d less than 17.
  4. Aug 20, 2005 #3
    sorry, but i happen to be very bad at maths, so could you please give me the whole explanation and asnwers??? i don't understand your explanation
  5. Aug 21, 2005 #4
    Hmm...I have not studied modulus, and my method & solution are likely incorrect :frown:
    Let there be two numbers, p & q, defined as follows:
    [tex] \frac{{n - 7}}{d} = p [/tex]
    and
    [tex] \frac{{2n + 3 - 1}}{d} = 2\left( {\frac{{n + 1}}{d}} \right) = q [/tex]
    Now, from the conditions of the problem, it is clear that [tex] \left( {p,q} \right) \in \mathbb{Z}^2 [/tex] and [itex] d > 7 [/itex]. Next, we just solve this system of equations for [itex] d [/itex]. From the first equation, we find that [itex] n = pd + 7 [/itex]. Substituting this to solve for [itex]d[/itex] in the second equation:
    [tex] 2\left( {\frac{{pd + 8}}{d}} \right) = q \Rightarrow \frac{8}{d} = \frac{q}{2} - p \Rightarrow d = \frac{{16}}{{q - 2p}} [/tex]
    Because [tex] \left( {p,q,d} \right) \in \mathbb{Z}^3 [/tex] and [tex] d > 7 [/tex],
    ...therefore [tex] d = \left\{ {8,16} \right\} [/tex].
    And those are the only two solutions for [itex] d [/itex].
    (I may be wrong...:frown:)
  6. Aug 21, 2005 #5
    Zurtex
    bomba923 the idea is that we don't give answers, we just try and help the person. Though you are on the right track there is no reason for d to be greater than 7, there are in fact a total of 5 solutions for d.
  7. Aug 21, 2005 #6
    VietDao29
    Why 5? :confused: I think there are only 4.
    Viet Dao,
  8. Aug 21, 2005 #7
    lurflurf
    1,2,4,8,16|16
  9. Aug 21, 2005 #8
    VietDao29
    Whoops,... N divides d, the remainder is 7. So d > 7.
    There are 2 only. :wink:
    But, in fact... 1 is obvious not the answer...
    Viet Dao,
  10. Aug 21, 2005 #9
    lurflurf
    a|b means b/a has no remainder
    or that there exist and integer s such that
    as=b
    in the mod notation
    a=b (mod c)
    means c|(a-b)
    the conditions given can be written
    d|(N-7)
    d|(2N+2)
    a basic theorem of arithmetic say
    if d|x and d|y
    then
    d|(ax+by) for all integers a and b
    so
    d|(a(N-7)+b(2N+2))
    so since we do not know N chose a and b relatively prime so that
    a(N-7)+b(2N+2) is a positive integer
    this is quite easily done
    as we want a+2b=0
    and 2b-7a>0
    and gcd(a,b)=1
    once it is
    d|(a(N-7)+b(2N+2))
    will be written
    d|r
    where r is a known natural number
    the factors of r are possibilities for d
  11. Aug 21, 2005 #10
    lurflurf
    good point 5 numbers come out of the
    d|16 step, but some are extraneous (ie do not meet the original requirements)
  12. Aug 21, 2005 #11
    Zurtex
    Yes, I'm sorry for confusing the situation there, the definition of remainder that I had in my head was perhaps a little too liberal for the question that was given.
  13. Aug 21, 2005 #12
    Well, [tex] d > 7 [/tex] because divisors less than or equal to seven cannot produce quotients with remainders of seven (it wouldn't make any sense, though perhaps I should have mentioned this in my solution post :frown:)
    *If we remove the condition d > 7, then there are indeed five solutions: d={1,2,4,8,16}. But d={1,2,4} will not produce remainders of seven...so eliminating those, you are left with d={8,16} as the only possible solutions (with the "remainder seven" requirement...and d=1 divides all integers anyway :shy:)
