Use the given equation for magnitude of drag force to calculate time taken
bobpeg123
A ball of mass 0.5 kg traveling horizontally through the air with speed v(t) experiences
a drag force DT (t) whose magnitude is given by:
DT (t ) = 0.01[v (t )] 2
The speed of the ball is found to reduce from 10 m/s to 8 m/s over a time interval t,
during which time the ball continues to travel horizontally. Calculate t.
I'm not entirely sure where to start with this. My notes give me the equation for drag forces falling vertically but I wasn't sure what to do because it's traveling horizontally.
Why would it be different for something moving horizontally?
Remember, the drag force always points in the opposite direction of the velocity.
But does that mean that the mass isn't important, or that gravity therefore doesn't matter?
Not for drag force. For a given object in a given fluid (air), the drag force is completely determined by only two things: how fast the object is moving (drag force is proportional to velocity squared) and which way it's moving (drag force always opposes the velocity). It doesn't matter whether gravity is in effect or not.
Ok, so I tried again and I got,
for v = 100m/s, D = 10N,
using D = bv^2, b=10/100^2 = 0.001
and then using v(t) = {sqrt(mg/b)... expotential stuff, which gave me an answer of 23m/s after 3 secs, but I don't know if that seems reasonable because as the velocity drops, so does the drag so how would it drop 77m/s in 3 seconds.
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
