Using a centrifuge to extract heavy water (help with the calculations please)
This discussion focuses on the feasibility of using centrifugation to extract heavy water (HDO) from normal water (H2O). The user references Cody from Cody's Lab, who utilized electrolysis for heavy water enrichment, but seeks a more efficient method through centrifugation. Key calculations involve the diffusion coefficients of H2O (2.299e-7 m²/s) and HDO (2.34e-7 m²/s), and the user explores the use of a partial differential equation (PDE) to model the distribution of HDO in a cylindrical centrifuge. The discussion concludes that achieving effective separation with a rim speed of 300 m/s is impractical for hobbyists.
  • Understanding of diffusion coefficients in fluid dynamics
  • Familiarity with partial differential equations (PDEs)
  • Knowledge of centrifugal force and its effects on liquid separation
  • Basic thermodynamics principles related to potential energy
  • Research the application of the diffusion equation in fluid dynamics
  • Learn about the Navier-Stokes equations and their simplifications
  • Explore the thermodynamic properties of mixtures, particularly H2O and HDO
  • Investigate practical centrifuge designs and their operational limits
Researchers, hobbyists, and engineers interested in experimental methods for heavy water extraction, as well as those studying fluid dynamics and thermodynamics in practical applications.
Gotbread
Hello everyone!
I have seen several DIY projects which successfully gathered heavy water
from normal water. For example Cody from codys lab used electrolysis
to "enrich" the water. This however is a messy process.
So i became curious, if this can be done easier by centrifugation.
Based on these data http://www1.lsbu.ac.uk/water/water_properties.html
around 1 in 6600 water molecules are heavy water (HDO). This would
have a density of ~1050kg/m³ compared to ~996kg/m³. This is not enough
to separate them under normal gravity but maybe this difference is enough
to be able to separate them in a centrifuge.
To get a feel for the forces needed, i want to calculate this. But here
is where i got stuck.
First, we assume a cylindrical centrifuge, spinning at a constant RPM.
We also assume that the system has reached a steady state so in the
frame of reference of the spinning liquid, nothing is moving. In that
frame, a fictitious force depending on the radius F(r) will act on the
liquid. Since the system is highly symmetric, it should be equivalent
to looking at only a 1D column along the radius.
In this steady state, the movement of particles due to the centrifugal
action and the movement due to diffusion will balance. Looking again at
the data table we find the diffusion coefficients of H2O and HDO, which
are (in SI) 2.299e-7 m²/s and 2.34e-7 m²/s respectively.
Here is my first confusion: the diffusion coefficient requires two
substances, is the second substance "normal water" (normal mixture of
H2O and HDO) ?
Second, to calculate the distribution, i am looking for a PDE i can
integrate numerically. I found the diffusion equation:
[tex]\frac{\partial \phi(r, t)}{\partial t} = \nabla \cdot \big[ D(r,t))\nabla \phi(r,t) \big][/tex]
with [itex]\phi[/itex] being the density and [itex]D[/itex] the collective diffusion coefficient.
(Can i assume the collective diffusion coefficient is the density weighted
average of the individual diffusion coefficients?)
Obviously, this equation does not include the radial force or the resultant
pressure.
I hope i can get around using the full navier-stokes equations, as they are
quite complicated. Is there a simpler form i can use? Essentially i am looking
for a 1D PDE.
It is probably easier to view this from a thermodynamic perspective. The centrifuge produces an effective potential for HDO (given by the mass difference to H2O), and your HDO molecules will be in thermodynamic equilibrium in this potential.
Rough estimate: A rim speed of 300 m/s (that is a very powerful centrifuge) leads to an effective potential of 45 kJ/kg or 0.5 meV if multiplied by the mass difference. kT at room temperature is about 25 meV. The separation will be quite weak.
That is a very quick but useful estimate. Since 300m/s rim speed is way out of reach as a hobbyist, it seems like this approach will not work.
Thanks for your answer!
  • · Replies 45 ·
