Using integration to find the total change in angle between two tangent lines
The discussion revolves around using integration to calculate the total change in angle between the tangent lines at two points on a function. Participants explore the mathematical formulation of this concept, including the role of differential changes in angle and the implications of integrating these changes over an interval.
  • Some participants propose integrating the angle defined by arctan(f'(x)) to find the total change in angle between tangent lines at two points.
  • Others question the necessity of the dx in the integral, suggesting it serves a different purpose compared to area calculations.
  • A participant suggests an alternative method of calculating the angle change by considering the tangent lines at points a and a+h, and summing the changes as one point "leap frogs" to the other.
  • Another participant provides a formulation involving limits and sums to express the angle change as a function of discrete points along the interval.
  • Some participants discuss the conditions under which the method may or may not work, including the continuity of the function and the behavior of the tangent lines.
  • One participant mentions that the differential change in angle can be expressed as the derivative of arctan(f'(x)), leading to a potential integration approach for net change.
Participants express various viewpoints on the formulation and approach to the problem, with no consensus reached on a single method or solution. Disagreements exist regarding the role of dx in the integral and the conditions necessary for the proposed methods to be valid.
Some participants highlight limitations related to the choice of points for tangent lines, particularly avoiding critical points where the slope may be zero, which complicates the angle definition.
This discussion may be of interest to those studying calculus, particularly in the context of integration and its applications to geometry and physics.
JamesGold
That is, adding up the differential changes in angle between two arbitrarily chosen points on a function, to find the total change in angle between the tangent lines of those two points. How can this be done?
Hi JamesGold! :smile:
Find the angle as a function of something (a coordinate, or the arc-length), and integrate.
The angle θ a tangent line of f(x) makes at x=a is equal to arctan(f'(a)).
So it would be $$\int_{a}^b\arctan(f'(x))dx$$
Thanks for the responses.
Intuitively, why the dx? arctan(f'(x)) gives you an angle, so why multiply it by dx?
Also, arctan(f'(x)) gives you the angle with respect to the x-axis, right? Would it be possible to do this problem by finding the change in angle between a tangent line at point x = a and a tangent line at point x = a + h, where h is inifinitely small, and then using this method to integrate across the entire function?
The dx is just there to tell you that the integration is done with respect to x. Can you attach a picture so I know what angle you are interested in?
And yes that angle is with respect to the x-axis
Are you interested in the curvature of the function? If so there are formula for finding curvature.
But doesn't the dx serve an actual purpose when finding the area under a function as opposed to just indicating that the integration is done with respect to x? When finding the area under a function, the dx represents the width of an infinitely thin rectangle of height f(x). So why doesn't the dx serve an actual purpose in arctan(f'(x))dx?
Here's my diagram:
The goal is to find the total angle ∅ between the tangent lines at the two blue points. I'm saying one way to do this is to start the two red points at the left blue point, and have them leap frog along the function until they reach the right blue point. Each time one red point leaps over the other, the angle d∅ between their tangent lines is found. If we add up all these d∅s from the left blue point to the right blue point, we should end up with the total angle ∅, right?
I realize that this is trivial because to find the angle between the tangent lines at the blue points one could simply place them end to end and measure the angle between them, but this is much more fun!
Let's say the end points are a and b. Let $$x_0=a, x_1=a+h, x_2=a+2h\cdots, x_n=a+nh=b$$ where $$h=\frac{b-a}{n}.$$ The angle as indicated in the diagram is $$\pi-\arctan(f'(x))-\arctan(f'(x+h)).$$ So you have to calculate$$\pi-\lim_{n\rightarrow\infty}\sum_{i=0}^n\bigg(\arctan(f'(x_i))+\arctan(f'(x_i+h))\bigg).$$
I think this is right but you can check numerically...
Cool! Three questions:
Can that be represented by an integral?
Will this work for any two points on any (continuous) function?
Must n go to infinity, or can it be any finite number and still get the right answer? If n = 1, isn't that the same as putting the tangent lines at A and B end to end?
1. Go here:
http://en.wikipedia.org/wiki/Riemann_integral
and look under: Riemann Sums. You'll see that you need a width. So I don't think you can write it as a Riemann Integral.
2. The slope can't be zero because the tangent line never intersects the x-axis and the concept of angle is meaningless. Therefore, try to avoid choosing critical points.
3. Yes if n=1, that's same as putting the tangent lines at a and b end to end. The following Mathematica code is useful for numerical results:
f[x_] := -x^2 + 4;
a := 0;
b := 1;
n := 1000;
h := (b - a)/n;
x[i_] := a + i*h;
Pi - (NSum[ArcTan[f'[x]] + ArcTan[f'[x + h]], {i, 0, n}])
If arctan f'(x) represents the angle at point x (which it does), then the differential change of angle at point x is the derivative of that: f''(x)/(1+f'(x)^2). So you can integrate that across your interval to find the net change in angle.
If you are interested in the total change (as opposed to net change), then you want your differential change to always be positive, so simply put absolute value bars around the integrand.
  • · Replies 46 ·
  • · Replies 53 ·
  • · Replies 18 ·
