Using tensions to find maximum velocity
  • Thread starter Thread starter MathewsMD
    Maximum Velocity
An object constrained by a cord moves in a circular path with a radius of 0.5m on a frictionless surface, where the cord breaks at a tension exceeding 16N. The maximum kinetic energy is derived from the relationship between tension and velocity, expressed as T = mv²/r - mg. The discussion highlights the challenge of isolating mass and velocity to find the maximum kinetic energy, with the suggestion to avoid separating m or v. The key point emphasizes that kinetic energy is calculated using the formula K = 0.5 mv². The conversation seeks clarity on the equations needed to solve for maximum kinetic energy effectively.
MathewsMD
An object is constrained by a cord to move in a circular path of radius 0.5m on a horizontal frictionless surface. The cord will break if its tension exceeds 16N. The maximum kinetic energy the object can have is:
Attempt at solution:
Well if tension can only be constant, then velocity is maximum when:
T = mv2/r - mg, right?
since v must be subtracted from to equal T, and this is the case at the bottom of the circle when it is motion.
So then I isolate m,
m = 16 / (2v2 - 9.8)
Then I use K = [8/(2v2 - 9.8)]v2
Now when I get here, I run out of equations to use. I am thinking I have forgotten something, but when I keep trying to isolate for v in other equations, I just keep getting the same answer.
Any help would be greatly appreciated! :)
Tension is just mv2/r. Gravity is acting perpendicular to the tension force.
Don't try isolate m or v separately. Remember, kinetic energy is .5 mv2.
