Value of alternating sum at infinity
  • Thread starter Thread starter timetraveller123
    Infinity Sum Value
timetraveller123
i showed that an 2 = a02 if n is even and 1 - ao2 if n is even
how am i supposed to evaluate this at infinity
I moved your thread to our homework section.
That is not correct (I guess the last word is supposed to be "odd", but both formulas don't work for either case).
Likes timetraveller123
How did you show that?
Anyway, suppose that a_0, a_1, a_2, ... converges to some number \alpha. Then that means that
a_0 - \alpha, a_1 - \alpha, a_2 - \alpha... converges to zero.
So, let's define a new sequence b_n = a_n - \alpha. Using the recurrence relation
a_{n+1} = \sqrt{1-a_n}
see if you can get an equation for \alpha that involves b_{n} and b_{n+1}. Then take the limit as b_n \rightarrow 0 and b_{n+1} \rightarrow 0
IF the limit exists, what do you know about ##{a_{n+1}\over a_n}## for very big values of ##n## ?
@mfb
i don't understand why you say that this is what i did
an+1 2 + an2 = 1
hence
first is
a02 next a12 is 1 - a02 then a22 is a02 isn't this alternating please point out my mistake to me
@stevendaryl
thats how i showed to both of you i am very sorry if am doing something wrong
when you say define new sequence as bn = an -a what is the a is it the a0 or an-1 thanks
@BvU
the limit approaches one but has my method been correct so far as others have pointed something is amiss
if you too could clarify that then i would gladly work along the line
thanks to all!
vishnu 73 said:
@mfb
an+1 2 + an2 = 1
hence
first is
The recurrence relation is a_{n+1} = \sqrt{1 - a_n}. If you square both sides, you get:
(a_{n+1})^2 = 1 - a_n, or
(a_{n+1})^2 + a_n = 1
So a_n is not squared.
Neither one. \alpha is the limit of a_n as n \rightarrow \infty. Do you know what a limit is?
We don't know the value of \alpha...that's what you're trying to find. But if lim_{n \rightarrow \infty} a_n = \alpha, then
lim_{n \rightarrow \infty} (a_n - \alpha) = 0
So take your recurrence relation
and write: a_{n+1} = \alpha + b_{n+1}, a_{n} = \alpha + b_n, where b_n is defined to be a_n - \alpha. Just plug it into the recurrence relation, and see if it tells you what must be true about \alpha.
@stevendaryl
omg so sorry such a careless mistake completely did not see that !
ok i have been following what you said but i lost what you mean when you when you say
so take your recurrence relation and write it as an+1 = a + bn+1 i don't how you got that from the recurrence relation please explain thanks
instead i did what bvu said
as
limn→ ∞ an+1 = an
and then using recurrence relation and quadratic formula yielded the answer please explain your method to me thanks!
It's not from the recurrence relation. It's just a definition. If a_0, a_1, a_2, ... is any sequence converging to some constant a, then I can define a new sequence b_0, b_1, ... by letting b_n = a_n - a. Then the sequence b_0, b_1, ... converges to zero. That's true for any convergent sequence. For example, consider the sequence
0/1, 1/2, 2/3, 3/4, 4/5 ...
Then a_n in this case would be n/(n+1). The limit is 1. So we define b_n = a_n - 1 = n/(n+1) - 1 = -1/(n+1). So b_n is the sequence:
-1, -1/2, -1/3, -1/4, ...
which clearly converges to 0. b_n is the "error" in replacing a_n by its limit. The error goes to zero as n \rightarrow \infty
So if you rewrite the recurrence relation in terms of a and b_n instead of a_n, then it becomes:
a_{n+1} = a + b_{n+1} (by definition of b_n)
a_n = a + b_n (by definition)
So substituting gives:
(a + b_{n+1})^2 + (a + b_n) = 1
or rearranging to get:
a^2 + a - 1 = - 2 a b_{n+1} - (b_{n+1})^2 - b_n
Now, take the limit as n \rightarrow \infty, and you get:
a^2 + a - 1 = 0
oh wow that's really smart thanks this is much more insightful solution sorry i couldn't just now see what you meant wonderful solution by the way
@stevendaryl: Do you show that the series converges somewhere? If you don't do that and just assume it, setting ##a_{n+1}=a_n## and solving it for ##a_n## is easier.
Likes stevendaryl
Use a cobweb diagram, such as in http://www.milefoot.com/math/discrete/sequences/cobweb.htm
The diagram would need to be modified a bit to match the current problem, but the basic idea is the same as in the link.
You can show that the sequence is contracting, or in this special case ##|a_n - a| > |a_{n+1}-a|## (the difference to the limit goes down), but that is not trivial.
Consider a sequence ##s_{n+1}= 2 s_n - 1##.
If we know ##s_0=1## it leads to ##s_n=1## for all ##n## and this sequence is convergent. But every other starting value leads to a diverging series.
Yeah, it amounts to the same thing. I thought it might be confusing to do that, because, of course, a_{n+1} \neq a_n for any n.
It just occurred to me that you can take the recurrence equation,
and just take the limit of both sides.
If you pay attention to post #11 you will see that not only does the limit ##\lim_n a_n = a## exist, but also that it equals the value where the two graphs ##y = a## and ##y = \sqrt{1-a}## intersect.
Likes stevendaryl
Search how to get the formula for the golden ratio Fibonacci series. Simple!
oh wow all of you all are really smart having so many ingenious methods really smart ency you all sorry i am just starting on olympiads please don't mind my mathematical immaturity
once thanks to all
