Building a Van de Graaff Generator: Tips and Considerations
Building a Van de Graaff Generator (VDG) allows for flexibility in collector size, with voltage depending on both the dome size and the distance from nearby conductors. A collector size of 24 to 30 inches is feasible with a 15 kV power supply, which is sufficient to generate high voltage, potentially reaching up to 750,000 volts if the dome is tall enough. The generator's height, around 6 feet, is crucial for achieving the desired voltage. Increasing the power supply current to 1 mA may enhance performance, although it's not strictly necessary. Overall, a 15 kV supply should adequately power the VDG, yielding around 10.5 kV after accounting for components like resistors and rectifiers.
BhutJolokia
I am building one. Not for school but for personal reasons. Is anyone here familiar or has built one before? I have some questions such as can the collector be any size? The maxium voltage of the collector is generally .8(70000r) with r being the radius of the collector. I was wondering if I could use a 24 to 30 inch collector with a 15kv power supply, or do I need to bump it up?
Scatterd post I apologize.
You can build a VDG any size you want. The voltage depends on the size of the dome but it also depends on the distance between the dome and other nearby conductors. It needs to be high enough above ground. If you want to use a power supply to spray the charge onto the belt the voltage you need is independant of the size of the VDG. 15 kV is more than enough. It should be able to supply a few ten µA.
Thanks man. I'm still looking for a dome but the one I am looking at will provide 750,000 volts. This is, of course, provided it is tall enough. I plan to make it roughly 6 feet tall, so I believe that is tall enough to get a high voltage. I may not reach the 750kv but I will get plenty regardless.
I was told if you increase the current from the power supply to 1mA it helps, even though (with leakage accounted for) you will not need anything near that. That's still to be determined.
Thanks for the reply man, I just wanted to make sure that even with a large enough collector 15kv would be enough to power this thing. (In reality, after the resistor and rectifier it comes out to about 10.5 kv.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
