B Variable focal length TV / screen
Excessive computer use can lead to eye strain due to fixed eye lens positions. The discussion explores the possibility of creating a screen that simulates a greater distance, such as making a 1m screen appear as if it is 4m away. One proposed solution involves equipping each pixel with a lens to project light in a near-collimated manner, though this could limit the viewing angle. Alternatives include using adjustable liquid lenses that track eye movement or employing light-field cameras to focus on specific areas of the screen. Overall, innovative approaches like these could enhance visual comfort and reduce eye strain in digital environments.
James125
Recently I have had a lot of eye strain from excessive computer use. The problem is because your eye lenses re stuck in a fixed position.
I wanted to know if it would be possible to make a screen that is 1m away look like it is 4m away for example. Would it be possible by making the screen out of focus somehow? Is it possible?
Interesting question. The first thought that comes to mind would be to equip each pixel with a lens that projects a near-collimated beam of light toward the user's eyes. This should make the screen appear much further away and also keep each pixel from being blurred into the others surrounding it. Unfortunately this would greatly limit the angle at which the screen can be viewed.
You can do this already by looking through a telescope the wrong way for example. I'm still trying to think how it would "look" if each pixel had a lens / how you would have to set this up..
Regarding the viewing angle, you could use liquid lenses that can be adjusted accordingly by using a camera that tracks your eye position.
Another interesting idea could be to use video that has been recorded with a light-field camera, so tracking where you look on the screen will also bring into focus that area. Now that would be interesting to see, maybe this is something that can also be used in VR (but I don't know if 360 degree light-field cameras exist).
Look up head-up-displays (no pun intended). They are usually projecting an image at infinity.
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
