Variable K elastic constant ?
The discussion centers on the concept of a variable elastic constant (K) in springs or materials, particularly whether a spring can exhibit different elastic constants during compression and decompression. It is proposed that rubber could serve as a model for such a spring, with K potentially being higher during stretching than when compressed. Theoretical considerations suggest that this is feasible, especially when accounting for factors like viscosity and plastic deformation. The phenomenon of "tension stiffening" is highlighted, where materials such as polymers and reinforced concrete demonstrate different stiffness characteristics under tension versus compression. This behavior is common in various materials, including fabrics, indicating a broader applicability of the concept beyond just springs.
cala
"Variable" K elastic constant ??
Difficult to put the topics on the right place...
Is there any spring (or any physical method) that could have different K elastic constant on one sense of movement than on the other?
For example K = 100 (or another value) when compressing and K = 75 (or another value) when decompressing?
I think that the simpler spring with variable K elastic constant could be made from rubber.
When you stretch this rubber spring the elastic constant would take a value K (the value of K depends on who hard is the rubber).
On the other hand during the compression of the spring the value of the elastic constant is K=0.
I’m not sure if practically a rubber spring could work but theoretically it is possible.
Sorta - if you throw in viscosity or plastic deformation or something like that. If you're hoping to use that to overcome the first law of thermodynamics though, no.
Almost any polymer (and some other materials) will have a different (and variable) K in tension from that in compression (except for small strains). Under tension, the polymer chains straighten out and stiffen - under compression they tend to buckle and are less stiff. The effect is called 'tension stiffening'.
Reinforced concrete does something similar - as do most fabrics (wool, cotton, etc)
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
