Variance of experimental data, compared to Theory
To compare experimental data to theoretical predictions, calculating the ratio of each reading to the theoretical result and determining the standard deviation of these ratios is a common approach. The discussion highlights the need for clarity on whether the goal is to assess the accuracy of a formula or confirm a specific distribution, such as Benford's Law. A Chi-Square test for goodness of fit is suggested for confirming Benford's Law, but issues arise if the observed and expected frequencies do not match. It's important to ensure that the total expected frequencies equal the total observed frequencies to avoid errors in the analysis. Overall, proper setup and understanding of statistical tests are crucial for accurate comparisons.
saad87
I'm looking for a way to compare experimental and theoretical data and determining if it obeys a certain law.
In particular, I'm writing a computer program that does this and at the moment what I'm doing is, I'm calculating the ratio of each reading with the theoretical result and calculating the standard deviation of the various resultant ratios.
I compare each ratio with the mean to see if its within one standard deviation. Are there any better approached than this? I'm not really a mathematician, and am more of a programmer so any help would be much appreciated.
Welcome to the world of statistics!
Some more information about the problem is needed. In particular, are you looking to test a formula to see how accurate it is (e.g. whether the errors are "acceptable"), or are you looking to confirm is a sample of random values has a specific distribution?
Basically I'm looking to confirm Benford's law in various files the user wishes to open.
If you are looking to confirm Benford's Law, then you have the expected distribution of numbers starting with 1,2,3,...,9, and you have the actual distribution given by your data.
I think a Chi-Square test for goodness of fit would be good here.
I just tried the Chi-square test, but the various online calculators basically tell me the total of my Observed and Expected frequences isn't the same. Is this because this test will fail if the observed freq. are too low than expected?
Thanks for all the help.
If your total expected does not equal your total observed, you have made some mistake in setting things up.
If you have N (observed) numbers in total and the fraction predicted by Benford's Law to start with i is f_i, then the number expected to start with i is e_i = f_i \cdot N. Since the f_i's sum to 1, the e_i's sum to N.
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
