Variation method (Quantum Mech.)
The discussion focuses on applying the variational method to determine an approximate ground-state wave function for a quantum particle in a one-dimensional potential energy function defined as V(x) = C|x|^{3}. The proposed wave function is ψ = Ae^{-ax^{2}}, leading to calculations for the kinetic energy and potential energy . The total energy is derived, and the minimization process is outlined, resulting in a critical value for 'a' that raises concerns about potential errors in the calculations.
  • Understanding of quantum mechanics principles, specifically the variational method.
  • Familiarity with wave functions and their normalization.
  • Knowledge of kinetic and potential energy calculations in quantum systems.
  • Proficiency in calculus, particularly integration techniques for evaluating energy components.
  • Study the variational principle in quantum mechanics for deeper insights.
  • Learn about normalization of wave functions and its implications in quantum mechanics.
  • Explore advanced integration techniques for evaluating complex integrals in quantum systems.
  • Investigate common pitfalls in variational calculations and how to avoid them.
Students and researchers in quantum mechanics, particularly those working on variational methods and energy calculations in quantum systems.
T-7
Hi,
Here's the problem:
Quantum particle moving in 1D. Potential energy function is V(x) = C|x|^{3}. Using the variational method, find an approx. ground-state wave function for the particle.
Using \psi = Ae^{-ax^{2}}, I find that
A = \left(\frac{2a}{\pi}\right)^{1/4}
Then,
<H> = <T> + <V> = -\frac{\hbar^2}{2m}\frac{d^{2}}{dx^{2}}+C|x^{3}|
<T> = -\frac{\hbar^2}{2m}A^{2}\left( -2a\int_{-\infty}^{+\infty}e^{-2ax^{2}} dx + 4a^{2}\int_{-\infty}^{+\infty}x^{2}e^{-2ax^{2}} dx \right)
which I work out to be
<T> = \frac{\hbar^{2}a}{2m}
For the potential energy component, I state that
<V> = CA^{2}\int_{-\infty}^{+\infty} e^{-ax^{2}} |x|^{3} e^{-ax^{2}} dx = 2CA^{2} \int_{0}^{+\infty} x^{3}e^{-2ax^{2}} dx
which I find to be
<V> = \frac{CA^{2}}{4a^{2}} = ... = \frac{C}{2a\sqrt{2a\pi}}
And thus
<H> = \frac{\hbar^{2}a}{2m} + \frac{C}{2a\sqrt{2a\pi}}
Minimising (diff. H wrt. a and set to zero) I obtain
\left(\frac{3Cm}{2\hbar^{2}\sqrt{2\pi}}\right)^{2/5},
but this (substituted back into the expression for <H> above) produces a rather ugly looking expression, which makes me suspicious that I have made a mistake somewhere down the line.
Can anyone see where (or if) I am going wrong?
Cheers!
Dr Hooley intended you to do the assessed work on your own. ;)
Whilst we are intended to work through the exercises ourselves, as far as I know we're encouraged to discuss all the problems, and the lecturer has been willing to take questions himself on any of the set problems. I've not reproduced my working in detail here for anyone to copy, nor am I asking for detailed working in reply. It's against this forum's policy to do your homework for you.
However, if you're under the impression that 'starred' Qs can't be discussed at all, I'll ask my tutor for clarification. Consider the thread closed.
  • · Replies 30 ·
