Variation of Elastic modulus with size
The elastic modulus of materials typically increases as their size decreases, attributed to factors like reduced dislocations and surface effects. In ceramics and oxides, the elastic modulus E shows a significant dependency on the size parameter H, especially for films thinner than 10 μm. Below this thickness, the growth mechanism leads to a stable structure with fewer defects, while thicker films exhibit more micro-defects due to agglomerated molecule groups. As thickness increases, the binding energy of these groups diminishes, affecting the microstructure. Ultimately, a thin film around 4 μm often demonstrates an optimal microstructure with minimal defects.
vinven7
It is generally well known that the elastic modulus of most materials become larger with decreasing size. This could be due to decreased number of dislocations, surface effects etc. Does anyone know how exactly does this increase? Considering a ceramic or an oxide, how does the Elastic modulus E vary with a size parameter H?
Not my field but I found an example here with explanation on the right..
http://openi.nlm.nih.gov/detailedresult.php?img=2801994_ijms-10-05257f10&req=4
The elastic (Young’s) modulus also varies pronouncedly with the thickness of film which is less than about 10 μm, but it approaches a constant when the thickness is more than about 10 μm. The relationship between elastic modulus and the thickness is shown in Figure 10. The main reason of this phenomenon seems to associate with the growth mechanism and its influence factors of the Pth films. When the thickness is less than 10 μm, the Pth mainly grows up in a stable manner on the base layer. But with increasing thickness, more and more agglomerated molecule groups are formed away from the base layer. Therefore, many micro-defects such as micro-cracks and micro-voids easily exist in the adjacent surface layer. At the same time, the binding energy of these agglomerated molecule groups becomes smaller and smaller because of the electrochemical influence or the influence of the metal substrate. Therefore, the microstructures of Pth films will change as the thickness increases. A thin film with the thickness of about 4 μm generally has a perfect microstructure with few defects
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
