Why is my particular solution not matching with the book's answer?
newtomath
Given t^2 y'' -t(t+2)y' = (t+2)y= 2t^3 and y1= t, y2= te^t
Find the particular solution-
I ve worked the problem to [ -2t^2 -2t] by:
-t * Integral [ 2t* te^t/ t^2e^t] + te^t * Integral [ 2t^2/ t^2e^t]
whereas the book states that it is simply -2t^2. Can you guys tell me where I made my mistake, I am stumped.
Is that first = supposed to be +?
To be honest, I don't completely understand this, but I'm not sure you've actually done anything wrong. You got the particular solution -2t^2-2t, and the book says -2t^2. But notice that one of the homogeneous solutions is t. If you add a linear combination of the homogeneous solutions to the particular solution, you get another equally valid particular solution. So, if -2t^2 -2t works, so does -2t^2 -2t + 2t = -2t^2.
Well a private solution here will be of the form:
At^3+Bt^2+Ct
where you can see quite immediately that A=0 (cause it has a term of t^4 which obviously gets nullified).
I did the calculation and got exactly as the book, try again.
PS
the C term doesn't get canceled though.
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
