Solving Systems of Inhomogeneous Linear ODEs
The discussion revolves around solving a system of inhomogeneous linear ordinary differential equations (ODEs) and the confusion arising from different methods yielding varying particular solutions. The user struggles to determine the correct coefficients for the particular solution, finding discrepancies between results from the method of undetermined coefficients and the variation of parameters. It is clarified that both methods can yield valid solutions if they are combined with the appropriate homogeneous solutions. Participants suggest verifying the solutions by substituting them back into the differential equations and recommend reviewing worked examples for better understanding. The conversation highlights the complexities involved in solving such systems and the importance of grasping the underlying concepts.
terryds
Determine the y_particular solution
I've tried this for hours but still don't get the correct value.
This is what I get:
The question is the same as the one I found from http://www4.ncsu.edu/eos/users/s/slc/www/COURSES/File2.pdf (Example 6.11.2).
The correct solution is as follows.
I get the coefficient for e^t is 1/8 and 1/16, but it says that the correct one is 1/4 and 0.
I really have no idea where I got wrong, please help me[UPDATE]
It turns out that the method of parameter variation REALLY yields DIFFERENT PARTICULAR SOLUTION from method of undetermined coefficients,
Undetermined Coefficient: http://www4.ncsu.edu/eos/users/s/slc/www/COURSES/File2.pdf (Example 6.11.2)
Variation of Parameters: http://www.wolframalpha.com/input/?i=solve+x'+=+-x+++4y+++e^t,+y'+=+x-y+1So which one is wrong, the undetermined coefficient or variation of parameter for this problem??
Or is it possible that those all are correct answers?
Please help. I'm so confused.
I've not looked at your shown work but am responding to your updated comment directly. Recall that your general solution is the particular solution plus the range of all possible homogeneous solutions. Thus adding any of the homogeneous solutions to the particular solution yields another particular solution. They are both right if the particular plus homogeneous solutions yields the same (correct) set of general solutions.
It is a generalization of the process of integration... to find the indefinite integral you find an anti-derivative (particular) and then add the homogeneous solution to d/dx = 0 namely an arbitrary constant. Note that any anti-derivative may be used as they all differ by a constant. For the more general linear diffeq. all of your particular solutions differ by some solution to the homogeneous eqn.
This is what I get:
View attachment 212491The question is the same as the one I found from http://www4.ncsu.edu/eos/users/s/slc/www/COURSES/File2.pdf (Example 6.11.2).
Have you tried substituting your solutions into the DEs, to see if they work? That is always the first step you should do.
Honestly, I think you should start over. Do yourself a favour and read a worked example in a book, say Boyce & DiPrima, an try to apply these steps to your problem. I think the whole concept of solving a system of inhomogeneous linear ODE is somewhat obscure to you, and that ist the source of your confusion.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
