Variational Method and Bound States
Einj
Consider a potential function V(x) such that:
\begin{cases}
V(x)\leq 0\text{ for }x\in[-x_0,x_0] \\
V(x)=0 \text{ for }x\not\in[-x_0,x_0]
\end{cases}
Show, using the variational method that:
(a) In the 1-dimensional case \lambda^2V(x) always possesses at least one bound state.
(b) In the 3-dimensional spherically symmetric case, V(|\vec r|), it possesses no bound states if \lambda^2 is made sufficiently small.
2. The attempt at a solution
The idea is to use the variational method, i.e.:
\frac{\langle\psi|H|\psi\rangle}{\langle \psi|\psi\rangle}\geq E_{ground},
to show that the average value of the energy is negative and hence the ground state energy is negative.
In my first attempt I used a gaussian trial function:
\psi(x)=\left(\frac{2a}{\pi}\right)^{1/4}e^{-ax^2}.
However the problem is that it turns out that the average value of the kinetic energy is \hbar^2a/2m and so, in order to determine whether the average energy is negative or not we need to know a explicitly. However, this is not possible since we have no insight on the actual shape of the potential.
It seems to me that this thing will turn out to be a problem for every trial function. How can I do that?
Thank you
In the 1D case the kinetic energy is proportional to ##a##. The potential energy is negative and goes as ##\sqrt{a}## when ##a## is small. Hence, if ##a## is small enough, the energy in that state will be negative, implying the existence of at least one bound state.
In the 3D case, the normalisation of the wave function gets additional factors of ##a## and the argument changes.
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
