Vector addition using components
To solve the vector addition problem, start by breaking down each leg of the hike into its x and y components using trigonometric functions. The first leg is 1.6 mi north, contributing only to the y component. The second leg, 2.2 mi at 35 degrees east of north, requires calculating both x and y components using sine and cosine. The final leg, 1.1 mi at 15 degrees north of east, also needs component analysis. After summing all x and y components, use the Pythagorean theorem to find the total distance from the starting point and determine the overall direction using inverse tangent.
chocolaterie
You will be hiking to a lake with some of your friends. the map says you will travel 1.6 mi north then 2.2 mi in a direction 35 degrees east of north, then finally 1.1 mi in a direction 15 degrees north of east. how far will you be from where you started and what direction will you be from your starting point?
I have no idea where to start. I drew a graph with 1.6 mi on the y-axis going north.
When you have a right triangle, remember the definition of the sine and cosine of an angle. Try to use that to write down the x component and y component of each part of the motion. Add up all the x components, and in a separate step add up all the y components.
