Writing Vector <1,7> as Sum of 2 Vectors
To express the vector <1,7> as a sum of two vectors, one parallel to <2,-1> and one perpendicular to it, the solution involves using vector decomposition. The first vector, parallel to <2,-1>, is calculated as <3,6>, while the second vector, perpendicular to <2,-1>, is <-2,1>. The dot product is relevant for confirming the orthogonality of the perpendicular vector. Visualizing the vectors as forming a right-angle triangle can aid in understanding the solution. This method effectively resolves the problem of vector decomposition.
Loppyfoot
Write the vector <1,7> as a sum of two vectors, one parallel to <2,-1> and one perpendicular to <2,-1>
DOt Product
I'm confused on where to begin this problem. Should I be using the dot product?
Thanks
i think you should draw out the vectors as they make up a right angle triangle.
I got the answer:
<-2,1> and <3,6>
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 16 ·
  • · Replies 17 ·
