Vector calculus for ellipse in polar coordinates
In summary: Also for part a) the R region it is the region between the ellipse to the circle right?In summary, the conversation is about a question regarding a parametric equation for an ellipse and finding the region for a given graph. The conversation includes solving equations, discussing the correct solutions, and determining the limits for the region
dragonxhell
Hello =]
I'm having trouble with this question, can somebody please help me with it! I'll thanks/like your comment if help me =)
![Question][1]
I know that for a ellipse the parametric is x=a sin t , b= b cos t t:0 to 2pi (?)
for part a) I drew up the graph but not sure if it's right. the circle have 1 radius and for the ellipse I able to find the x= 2
(x-1)^2 =9
sqrt(x-1)^2=sqrt9
x-1=3
x=4
for y=2sqrt2
y^2=8
sqrty=sqrt8
y=sqrt4 sqrt 2
y= 2sqrt2 or 2.8
So the region should be the circle? since the ellipse like cover the whole circle?
Thank you very much for helping!
Cheers.
That would be valid if the ellipse was centered at the origin, which is not the case here. (but only a slight adjustment needs to be made).
(x-1)^2 =9
sqrt(x-1)^2=sqrt9
x-1=3
x=4
for y=2sqrt2
y^2=8
sqrty=sqrt8
y=sqrt4 sqrt 2
y= 2sqrt2 or 2.8
There exists two solutions to each of these equations.
Cheers.
The region is not exactly a circle, but the unit circle is completely contained within the ellipse.
the region happen is when 2 of graph meet each other?
so for x it's 4 and -4 and for y its 2sqrt2 and -2sqrt 2 right?
i did a sketch of it, by any chance you know how to do this question? =(
Mod note: The image was way too large. Please scale the image down to about 900 x 600 pixels and edit this post to include it again, or add it in a new post in this thread.
No, for the first equation, you solve ##(x-1)^2 = 9## so ## x-1 = \pm 3## What are the two solutions?
Similarly for the other equation.
Your sketch shows the ellipse concentric with the unit circle, but this is incorrect since the ellipse has a centre (1,0). When you find the correct solutions to the above, it should fix things.
@dragonxhell: To get started on this problem you need to substitute the polar coordinate values for ##x## and ##y## into the equation of the ellipse and solve it for ##r##. That should lead you to the answer for part b. Then you will use the form$$
\int_0^{2\pi} \int_{r_{inner}}^{r_{outer}} \frac 1 {r^3}r\,drd\theta$$
o so the centre is (1,0) and the equation you show me I have already obtained
But don't you move the 1 over? To just simply get x by it self? So it should be 4 and -3 (-4+1?)
Is this right? Can somebody double check this for me? It seem right to me...
(x−1)²/9 + y²/8 = 1
8(x−1)² + 9y² = 72
8x² − 16x + 8 + 9y² = 72
9(x²+y²) − x² − 16x + 8 = 72
9(x²+y²) = x² + 16x + 64
9(x²+y²) = (x + 8)²
9r² = (r cosθ + 8)²3r = r cosθ + 88 + r cosθ = 3r
a = 8, b = 3
c)R is region outside circle: r = 1*and inside ellipse: r = 8/(3−cosθ)
Limits:*1 ≤ r ≤ 8/(3−cosθ)
0 ≤ θ ≤ 2πƒ
= 1/(x²+y²)^(3/2)
= 1/(r²)^(3/2)
= 1/r³∫∫ ƒ dA = ∫ [0 to 2π] ∫ [1 to 8/(3−cosθ)] 1/r³ * r dr dθR. . . . .
= ∫ [0 to 2π] ∫ [1 to 8/(3−cosθ)] 1/r² dr dθ. . . . .
= ∫ [0 to 2π] (−1/r) | [1 to 8/(3−cosθ)] dθ. . . . .
= ∫ [0 to 2π] (−(3−cosθ)/8 − (−1)) dθ. . . . . = ∫ [0 to 2π] 1/8 (cosθ + 5) dθ. . . . .
= 1/8 (sinθ + 5θ) | [0 to 2π]*. . . . .
= 1/8 [(0 + 10π) − (0 + 0)]. . . . .
= 5π/4
(x−1)²/9 + y²/8 = 1
8(x−1)² + 9y² = 72
9(x²+y²) = (x + 8)²
a = 8, b = 3
0 ≤ θ ≤ 2πƒ
= 1/(x²+y²)^(3/2)
= 1/(r²)^(3/2)
= 5π/4
Yes. Very nice.
LCKurtz said:
Yes. Very nice.
Can you please check this question for me because my answer is different to my friends and they say its wrong...
Given the equation: G= (x^3 -3xy^2)I +(y^3-3x^2y)j +2k is conservative find the potential function for the fields that are conservative
My answer
f:grad f=F
fx=x^3-3xy^2
fy=y^3-3x^2y
fz=z
integral (x^3-3xy^2)dx
=x^4/4-3x^2y^2/2 +h(y, z)
fy or f'y= -3x^2 y +hy(y, z)
fy=y^3-3x^2y= -3x^2y+hy(y, z)
hy(y,z)=y^3
Integral y^3 dy = y^4/4 +gz
fz=0 because no z term ^
Integral 0dz =c
F= x^4/4-3x^2y^2/2 +y^4/4+c <-potential function
My answer
f:grad f=F
There is no F anywhere. Don't you mean grad f = G?
fx=x^3-3xy^2
fy=y^3-3x^2y
fz=z
Is ##f_z = z## or ##f_z = 2##? Look at G.
hy(y,z)=y^3
Integral 0dz =c
Poorly written. At this point you have$$
f = \frac {x^4} 4 - \frac {3x^2y^2} 2 +\frac{y^4} 4 + h(z)$$
Now you need to take ##f_z## and set it equal to the third term, whether it is a ##2## or a ##z##. You don't get ##f_z=0## either way.
sorry I type it all up on my phone and when I submit it it's so messy...
so you are saying
my integral y^4/4 must equal to fz which is z
So the final answer is
F=x^4/4 -3x^2y^2/2 +y^4/4 +z^2/2
1. What is the equation for an ellipse in polar coordinates?
The equation for an ellipse in polar coordinates is r = a(1-epsilon*cos(theta)), where a is the semi-major axis and epsilon is the eccentricity of the ellipse.
2. How do you find the eccentricity of an ellipse in polar coordinates?
The eccentricity of an ellipse in polar coordinates can be found by taking the square root of 1 minus the ratio of the semi-minor axis (b) squared over the semi-major axis (a) squared, or epsilon = sqrt(1-(b^2/a^2)).
3. What is the parametric equation for an ellipse in polar coordinates?
The parametric equation for an ellipse in polar coordinates is r = a(1-epsilon*cos(theta)), theta = t, where t is the parameter and a and epsilon are constants for the ellipse.
4. Can vector calculus be used to calculate the area of an ellipse in polar coordinates?
Yes, vector calculus can be used to calculate the area of an ellipse in polar coordinates. The area can be found by taking the integral of 1/2*r^2*d(theta) from 0 to 2*pi, where r is the equation for the ellipse in polar coordinates.
5. How do you convert between Cartesian and polar coordinates for an ellipse?
To convert from Cartesian coordinates (x,y) to polar coordinates (r,theta) for an ellipse, use the equations r = sqrt(x^2+y^2) and theta = arctan(y/x). To convert from polar coordinates (r,theta) to Cartesian coordinates (x,y), use the equations x = r*cos(theta) and y = r*sin(theta).
