Vector Calculus Question in Lagrangian Mechanics
4 replies · 2K views · last reply
Travis091
Hi guys. I hope this isn't a bad place to post my question, which is:
I'm reading some lecture notes on Lagrangian mechanics, and we've just derived the Euler-Lagrange equations of motion for a particle in an electromagnetic field. It reads:
[tex]m \ddot{\vec{r}} = -\frac{e}{c} \frac{\partial \vec{A}}{\partial t}-e\nabla \phi(\vec{r})+ \frac{e}{c} \nabla (\dot{\vec{r}}\cdot \vec{A})[/tex]
(A and phi are the vector and scalar potentials, respectively). Now the author switches to index notation, and I get lost in the process. The author gives:
[tex] m \ddot{r}^a = - \frac{e}{c} \frac{\partial A^a}{\partial t} - e \frac{\partial \phi(\vec{r})}{\partial r^a} + \frac{e}{c} \left( \frac{\partial A^b}{\partial r^a} - \frac{\partial A^a}{\partial r^b}\right) \dot{r}^b[/tex]
My problem is with the third term above. Is the summation over b implied? I thought that it is bad form to repeat a summation index three or more times. Also, if we are to look at the a-th component of the gradient of the inner product, it should be:
[tex] \left(\nabla (\dot{\vec{r}}.\vec{A})\right)_a = \left(\nabla (\dot{r}_i A^i)\right)_a=\frac{\partial}{\partial r^a} \left ( \dot{r}_i A^i \right) = \dot{r_i}\frac{\partial A^i}{\partial r^a}[/tex]
which is clearly not equal to the text. I have a feeling I'm doing something stupid, and it would be great if someone can point out my mistake(s).
Thanks.
Yes I tried using the identity which you mention:
[tex]\nabla(\mathbf{A} \cdot \mathbf{B}) = (\mathbf{A} \cdot \nabla)\mathbf{B} + (\mathbf{B} \cdot \nabla)\mathbf{A} + \mathbf{A} \times (\nabla \times \mathbf{B}) + \mathbf{B} \times (\nabla \times \mathbf{A})[/tex]
so:
[tex]\nabla(\mathbf{\dot{r}} \cdot \mathbf{A}) = (\mathbf{\dot{r}} \cdot \nabla)\mathbf{A} + (\mathbf{A} \cdot \nabla)\mathbf{\dot{r}} + \mathbf{\dot{r}} \times (\nabla \times \mathbf{A}) + \mathbf{A} \times (\nabla \times \mathbf{\dot{r}})[/tex]
but I didn't get anywhere. I could have made a mistake while using this identity, I will try again later, but more importantly, why is my expression for the third term incorrect? That is what I would really like to understand. I want to clear out my misconception.
Thanks.
This equation is wrong. Instead of the partial time derivative, there should be total time derivative of the vector potential. Then you can use
[tex]\frac{d \vec{ A }}{ d t } = \frac{ \partial \vec{ A } }{ \partial t } + ( \vec{ v } \cdot \vec{ \nabla } ) \vec{ A }[/tex]
That's it! Many thanks for your help. It was actually my mistake, the author skipped a step and jumped from the Lagrangian to the second equation above. I filled the missing step incorrectly, mixing up the total and partial derivatives.
