Vector potential from magnetic field
6 replies · 2K views · last reply
spaghetti3451
<<Mentor note: Moved from non-homework forum>>
If a uniform magnetic field ##{\bf{B}}=B_{z}{\bf{\hat{z}}}## exists in a hollow cylinder (with the top and bottom open) with a radius ##R## and axis pointing in the ##z##-direction, then the vector potential
$${\bf{A}}=\frac{BR^{2}}{2r}{\bf{\hat{\phi}}}?$$
using Stokes's theorem.
How can you prove this?
Start from the definition of the vector potential, in terms of the field, and apply stokes' theorem.
What is it you are trying to prove exactly and why?
If you want to prove the vector potential is consistent with the given field, then use the definition to get the field from the potential.
I am trying to prove that
This is something that has appeared in my reading of Sakurai.
##\displaystyle{{\bf B}=\nabla \times {\bf A}}##
##\displaystyle{\int {\bf B}\cdot{d {\bf l}}=\int (\nabla \times {\bf A})\cdot{d{\bf S}}}##
##\displaystyle{\int B_{r}(2\pi R)=\int (0,-\frac{BR^{2}}{2r^{2}},0)\cdot{d{\bf S}}}##
##\displaystyle{(0,0,0)=\int (0,-\frac{BR^{2}}{2r^{2}},0)\cdot{d{\bf S}}}##
Does it look good so far?
The second line is not correct.
Also note that the vector potential generally is not unique but subject to gauge transformations.
