Vector Properties: Divide by Direction Impossible
In summary, the conversation discusses the concept of dividing a vector by another vector and the limitations of this operation. It is pointed out that if two vectors are along the same line, then division can be performed to get the scalar quantity. However, in most cases, dividing vectors is not possible and instead, one can focus on dividing individual components to get the desired result.
Prashasti
63
It is well known that a vector can't be divided by a vector, as a direction can't be divided by a direction. Keeping this in mind, I used the equation, v→ = u→+a→t, and wrote it as t = v→ -u→/a→. Now, isn't it wrong to write the equation like this? As , in it, a vector, that is v→ -u→ is being divided by another, (i.e. a→)?
This shows only equation representation. Actually you can't perform any operation like dividing.
Consider
$$\vec v = \vec u + \vec a t\\
\vec v - \vec u = \vec a t$$
If t > 0, then the resultant of ##\vec v - \vec u## has the same direction as ##\vec a##. If t < 0, then the resultant of ##\vec v - \vec u## has the opposite direction as ##\vec a##.
If you know that two vectors ##\vec a## and ##\vec b## are along the same line (i.e. one equals the other multiplied by a scalar), then you can divide one by the other to get the scalar.
Otherwise, then you indeed cannot divide them.
Likes 1 person
If you are interested in the scalar, then all you need to divide is any (non-zero) component into its corresponding component.
In fact when you are dividing one vector by another, you are in essence carrying out three divisions instead of one to get the same result.
Likes 1 person
Yes, it is incorrect to divide a vector by another vector. In mathematics, division is defined as the inverse operation of multiplication, but for vectors, there is no defined operation for division. Vectors are quantities that have both magnitude and direction, and dividing by a vector would not make sense in this context.
In the equation t = v→ -u→/a→, the vector v→ -u→ represents the displacement between two points, and a→ represents the acceleration. It is important to note that the division symbol in this equation is not meant to be interpreted as a mathematical operation, but rather as a way to represent the relationship between these quantities.
Furthermore, the equation v→ = u→+a→t is a simplified version of the kinematic equation for constant acceleration, which is derived from the fundamental equations of motion. This equation is valid for one-dimensional motion and cannot be used in a situation where the acceleration is not constant.
In conclusion, it is incorrect to divide a vector by another vector. Rather than trying to divide by direction, it is important to understand and use the appropriate equations and concepts for vector operations in order to accurately represent physical quantities.
1. What are vector properties?
Vector properties refer to the characteristics or attributes of a vector, which is a mathematical object that has both magnitude and direction. These properties include length, direction, and components.
2. What does it mean to divide a vector by direction?
Dividing a vector by direction is a mathematical operation that is not possible because direction is not a numeric value that can be divided. It is an essential part of a vector and cannot be divided or separated from the magnitude.
3. Why is dividing a vector by direction impossible?
Dividing a vector by direction is impossible because direction is a non-numeric quantity that cannot be divided. It is an integral part of a vector and cannot be separated or reduced to a numerical value.
4. Can a vector be divided by its length?
No, a vector cannot be divided by its length. Length is a scalar quantity, while a vector is a combination of magnitude and direction. Therefore, they cannot be divided or treated as equivalent quantities.
5. Are there any exceptions to the rule that dividing a vector by direction is impossible?
No, there are no exceptions to this rule. Direction is an essential part of a vector and cannot be divided or separated from its magnitude. Any attempt to divide a vector by direction would result in an undefined or meaningless value.
  • Differential Geometry
  • Other Physics Topics
