Vector Valued Function Using (or misusing) Trig Identity
The discussion revolves around converting a vector valued function (VVF) into a real valued function for easier sketching of a curve. The VVF given is r(θ)=3sec(θ)i+2tan(θ)j, which transforms into a hyperbola represented by the equation (x^2)/2=(y^2)/2+1. The user attempts to manipulate the equations derived from the VVF but becomes confused when trying to apply trigonometric identities, particularly regarding the relationship between secant and tangent. The conversation highlights the importance of correctly applying these identities and clarifies that (sec(θ))^2 - (tan(θ))^2 equals 1, which is crucial for solving the problem. Overall, the thread emphasizes the challenges of transitioning from VVF to real valued functions while ensuring accurate mathematical transformations.
kmacinto
The context of the problem is that it's a vector valued function (VVF) problem where I'm supposed to sketch a curve generated by a VVF. To make the sketching easier I'm supposed to convert a VVF to a real valued function so that I can take advantage of the shape of a curve covered in previous sections of the text in real valued function format.
Sketch the curve represented by the vector valued function r(θ) and give the orientation of the curve. r(θ)=3sec(θ)i+2tan(θ)j.
The real valued function that r(θ) converts to is a hyperbola given by the equation (x^2)/2=(y^2)/2+1
The steps given in the book are:
1) from r(θ) set:
x=3sec(θ), y=2tan(θ)
2) (x^2)/2=(y^2)/2+1 which is the solution.
My steps attempted are:
1) divide x and y by the constants leaving:
x/3 = sec(θ) and y/2 = tan(θ)
2) equate both equations leaving:
x/3 + y/2 = sec(θ) + tan(θ)
3) square both sides leaving:
(x/3)^2 + (y/3)^2 = (sec(θ))^2 + (tan(θ))^2
and here's where I'm stuck...
Because both sides need a negative to work. For instance, for the (y/3)^2 to be on the right and positive it needs to be negative on the left and to get the right side to equal 1 using (tanθ)^2 + 1 = (secθ)^2, I need either the (tanθ)^2 or the (secθ)^2 to be negative where they're at now. Right?
Totally flustered!
Ken
PS. The attachment is the problem and given solution from the textbook.
Hi Ken! :smile:
I don't understand what you're doing. :confused:
What is sec2θ - tan2θ ? :wink:
(a+ b)^2\ne a^2+ b^2
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 40 ·
  • · Replies 21 ·
11K
  • · Replies 27 ·
