Vectors, line contained within plane
For a line to be contained within a plane, it must not be parallel to the plane itself, as parallel lines do not intersect the plane. Instead, a line that lies in the plane shares points with it. The direction vector of the line is perpendicular to the normal vector of the plane, confirming its containment. Thus, the relationship between the line and the plane is defined by their intersection rather than parallelism. Understanding these geometric relationships is crucial for solving related problems.
craka
It seems to be obvious. But would like to check that for a line to be contained in a plane it needs to be parallel. Correct?
parallel to what?
Parallel to the plane? No, a line that is contained in the plane is not, by definition, "parallel" to that plane. In order to be parallel, the line must have no points in common with the plane which is clearly not true if it is contained in the plane.
It is true that if a line is contained in a plane then its direction vector is perpendicular to the normal vector of the plane.
