What is the relationship between club length and club speed in a golf swing?
The discussion focuses on the relationship between golf club length and club speed, specifically how increasing the shaft length affects the speed of the clubhead during a swing. The original poster seeks to mathematically demonstrate that a 3 to 4-inch increase in shaft length does not significantly impact club speed, assuming constant angular velocity. A key formula mentioned is v = rω, indicating that velocity is proportional to the radius (shaft length) and angular velocity. Additionally, it is noted that the energy in the swing is proportional to the square of the velocity, suggesting that longer shafts may store more energy. Overall, the conversation highlights the complexities of quantifying the impact of club length on performance.
rhill100
Hi everyone,
I started what I thought would be a simple algebra/trig problem and quickly learned that I was dead wrong. At least I think I am wrong. I need to determine how much the speed of a particle moving along an arc segment changes as the length of the distance to the center point changes if the angular velocity remains constant. I think I'm using the term angular velocity correctly... My specific goal is to show mathematically to a couple of unbelieving friends that increasing the length of a golf shaft by 3 or 4 inches is not going to make as much of a difference in club speed as they believe it is. Assuming that two golf swings are exactly the same, how fast if the club head moving is the shaft is 44 inches long versus 48 inches long. What formula(s) should I be looking for? Does anyone know of a website that may have some parametric functions on it that I could just plug in the numbers and see the difference? All I'm looking for is a percent of change between the two numbers. Thanks in advance, any guidance will be greatly appreciated.
Rob
the percentile velocity increase equals the precentile club length increase because
v=r\omega
v=r\omega
But you really need to worry about the energy stored in the swing, which is going to be proportional to v^2.
So the energy will go as the square of the club length.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
