Velocity and particle of a particle with a wave going through
The discussion centers on finding the velocity and acceleration of a particle in a medium while a wave passes through. It highlights the distinction between the speed of the wave, which is determined by the medium's properties, and the velocity of individual particles, which undergo simple harmonic motion. The wave's speed is calculated as the square root of the ratio of elastic to inertial properties of the medium. Participants express confusion about the interaction between the wave and the particle, questioning whether the particle is floating on a water wave or influenced by an electromagnetic wave. Clarification is provided that while the wave travels at a constant speed, the particles experience varying speeds and accelerations.
sauri
2) Find an expression for the velocity of a particle in the medium while a wave is going through, and its acceleration.
I first thought that the particle might under go simple harmonic motion when the waved passed but then I remembered that the speed of a wave is determined by the properties of the medium it travels through. hence v is equal to the square root of elastic property/inertial property. So now I am confused as to how to solve this.
What is the mechanism for physical interaction between the wave and the particle? Is the particle floating on a water wave? Or is it a charged particle that is influenced by an EM wave traveling by?
Do not confuse the speed of the wave with the velocity of the particles . Each particle undergoes simple harmonic motion, as you said (so their speed is not constant, nor is their acceleration). The wvae, on the other hand, has a constant speed, given by the square root you are describing.
Hope this helps
Pat
