How Does Friction Affect a Sphere's Velocity on a Ramp?
The discussion centers on the effects of friction on a sphere's velocity as it transitions from a horizontal surface to a ramp inclined at 25 degrees. A sphere moving at 10 m/s on a frictionless ramp maintains its velocity upon leaving the ramp, while on a ramp with friction, the sphere experiences a loss of kinetic energy due to the opposing force of friction, resulting in a velocity less than 10 m/s. The key takeaway is that friction affects the sphere's ability to maintain its speed, with frictionless conditions allowing for greater velocity compared to scenarios involving friction.
  • Understanding of Newton's laws of motion
  • Familiarity with kinetic energy concepts
  • Knowledge of rolling versus sliding friction
  • Basic principles of inclined planes in physics
  • Study the principles of kinetic energy conservation in rolling objects
  • Learn about the differences between static and dynamic friction
  • Explore the effects of incline angles on object motion
  • Investigate the equations of motion for rolling objects on inclined planes
Students studying physics, particularly those focusing on mechanics, as well as educators looking for clear explanations of friction's impact on motion dynamics.
moondawg
Suppose a sphere going 10m/s on a horiz. surface is going toward a frictionless ramp(incline of 25 degrees). Would its velocity, as it leaves the top of the ramp, be greater,less than or equal to its velocity if the ramp had friction?
I thought that the speed would be less than the vel of the ball rolling up a ramo with friction bc if the ball is slipping up the ramp than there would be less total kin energy( when taking translational and rotational kin energy into account) and that would dec its speed. I don't know if my logic is correct though?
When the phase "frictionless" is used, it doesn't mean the ball would "slide" up the ramp, it implies that there would be nothing opposing the motion of the ball.
If the ball moves up a frictionless ramp, there is no force opposing motion.
If the ball moves up a ramp with friction, there is a force (friction) opposing motion.
So the moment you include friction, it means there is something opposing the movement in some way (trying to slow it down).
So which allows the faster motion? With or without friction?
Things are a bit different when objects are rolling. Friction between surfaces is due to sliding, one over the other (except for rolling friction, which is due to a different mechanism).
When an object rolls, it does not "invoke" dynamic friction in the direction that it is rolling, as it is not sliding. This, of course, is why the wheel was such a hit when it was invented.
If the rotation rate of the object does not match its rate of translation, so that the object spins against the surface, the friction can actually speed-up or slow-down the translational motion of the object.
Well I took it to be sliding up until the ramp - then depending on the ramp, the result would ensue as follows:
If you are sliding and hit a frictionless ramp at 10m/s (ignoring gravity) there would be nothing to slow it down. No friction applied would mean it doesn't start rolling. Leaves at 10m/s.
If you are sliding and hit a ramp with friction at 10m/s (ignoring gravity) there would be a force applied that would cause the sphere to start rolling, so there would be a loss of kinetic energy and the sphere would leave at < 10m/s.
At least that's my logic behind it. Sorry my original post wasn't very clear on the matter, I tried to clarify 'frictionless' and why it doesn't mean it would slide up the ramp - if it's already rolling for example - before continuing and it just confused things.
I removed my example for the purpose of clarity.
  • · Replies 32 ·
  • · Replies 29 ·
23K
