Velocity as a function of distance [v(x)]
  • Thread starter Thread starter BitterX
    Function Velocity
The discussion focuses on a physics problem involving a mass moving across a plane with a frictional force defined by the equation μ = λx². The user initially questions the applicability of the kinematic equation v² = v₀² + 2aΔx due to non-constant acceleration. They later derive the relationship v(x)² = v₀² + (2/3)gλx³ by integrating acceleration, confirming the approach is correct. A key point raised is the importance of using proper signs for vectors when considering forces, velocity, and acceleration. The conversation emphasizes the need for careful mathematical treatment in problems involving variable forces.
BitterX
a body with mass M moves across a plane with friction
friction constant:
\mu = \lambda x^2
the body starts at x=0
with velocity v0
find at what x
the body stops
and what was the velocity half way there.
v^2=v_0^2+2a\Delta x
obviously,
F(x)=mg\mu = mg\lambda x^2
so
a(x)=g \lambda x^2
so in the equation v^2=v_0^2+2a\Delta x
I get
v^2=v_0^2+2g\lambda x^3the Question is, can I use this equation? the acceleration is not constant and this equation
depend on the fact that x=v_0t+ \frac{a}{2}t^2
and v=v_0+at
(and it's not true for non-constant acceleration)
if I cant, how can I integrate the acceleration?
or how do I get v(x)?
Thanks.
EDIT:
I used a= v\frac{dv}{dx}
therefore
vdv=adx
\int_{v_0}^{v(x)}{vdv} = g\lambda \int_{0}^{x}{x^2}
\frac{1}{2} ( v(x)^2- v_0^2) =\frac{1}{3} g\lambda x^3
v(x)^2=v_0^2+\frac{2}{3}g\lambda x^3
does that seem right?
I don't see anything wrong with your edited solution.
friction constant:
\mu = \lambda x^2
with velocity v0
obviously,
so
a(x)=g \lambda x^2
therefore
vdv=adx
Does the friction increase speed?
Remember that velocity, acceleration and force are all vectors. You need to use proper signs with them.
ehild
ah, of course... it's with a minus :)
on paper I actually did it with a minus. Thanks for pointing it out though!
