B How Does Time Dilation Influence Perceived Velocity?
AleksanderPhy
Hello I have a question about how time effects velocity:So we have a car on Earth traveling 200m with 5 seconds we get that car moves 40m/s and 40x3600=144000 and 144000:1000=144km/h so car on Earth travels 144km/h now let's consider a that there is observer on spacecraft traveling 0.5c through time dilation formula:t=1/√1-v/c we get that observer on spacecraft get's that car travels 200m with 0.5 seconds so observer thinks that car goes 1440 km/h. Does this mean that time effects velocity?
There's a mistake in your formula, it should be 1/√(1-(v/c)2). You also need to include the effect of length contraction but from the point of view of the spacecraft , the car is traveling at roughly 0.5c (at little more or a little less depending on the directions).
Velocity Addition Formula
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
So, to calculate a proper time of a worldline in SR using an inertial frame is quite easy. But I struggled a bit using a "rotating frame metric" and now I'm not sure whether I'll do it right. Couls someone point me in the right direction? "What have you tried?" Well, trying to help truly absolute layppl with some variation of a "Circular Twin Paradox" not using an inertial frame of reference for whatevere reason. I thought it would be a bit of a challenge so I made a derivation or...
